Boost gauge chatter?
do you have brass tubing running to the gauge? I have installed serveral that if you use brass it makes a crazy noise (like sending the intake pulse thru the tubing and amplifying at the gauge). Removed the brass and either went steel braided line or just the plastic tubing it comes with. that quieted them down back to normal
It's tapped into the intake horn. It only starts at 20 psi. My 1/8 NPT fitting is protruding past the ceiling of the intake. I wonder if it is creating turbulence around the hole?
I had the problem with my first isspro EV. Got a new guage and it worked fine. no more problem. After i figured out it was the gauge, I attempted to try and fix it. Ended up braking the gauge. Bummer...... Sorry for the bad news
Dracula
15
Nov 30, 2008 09:49 AM
