Boost fool ?
Old Nov 12, 2006 | 04:43 PM
doug60's Avatar
Boost fool ?
Smarty on 9 & EZ on 2
I thought the EZ did boost fooling, but I'm getting a over boost code.
Old Nov 12, 2006 | 04:51 PM
morkable's Avatar
do you have a boost guage??
Kevin
Old Nov 12, 2006 | 04:55 PM
doug60's Avatar
Kevin
Yes I do, Im not seeing the boost I should.
Old Nov 12, 2006 | 04:57 PM
morkable's Avatar
what kind of numbers are you seeing, and where is your boost guage plumbed in at?
Kevin
Old Nov 12, 2006 | 05:06 PM
doug60's Avatar
Kevin
Intake ram ,40 something
Old Nov 12, 2006 | 05:15 PM
morkable's Avatar
What turbo you running?
Kevin
Old Nov 12, 2006 | 05:18 PM
doug60's Avatar
Kevin
Idaho CTD Twins ( smaller set ) there happy at 60 Lbs
Old Nov 12, 2006 | 08:30 PM
morkable's Avatar
Sorry about that, I didnt look close enough at your sig,, lol Im not sure what is going on,,,, I just have to think that there isnt any boost fooling going on, that is the number that you would get as stock
Kevin
Old Nov 12, 2006 | 09:02 PM
doug60's Avatar
I have hit 60 pounds with the TST.
The TST is out of the loop at this time.
Old Nov 12, 2006 | 09:50 PM
morkable's Avatar
I guess obviously the edge is not doing any boost fooling. I didnt know that before. I know that the juice is doing boost fooling. The cel is telling you that the twins are trying to put out more boost than the engine is ready for, so the engine gives a code
Kevin
Old Nov 13, 2006 | 11:02 AM
qzilla's Avatar
Is your EZ adjustable?
I know some cases there are modules that do not do boost fooling in the off position. If you tried to run it in the off position (EZ) just to see what the Smarty was doing then that might be the issue?
Old Nov 13, 2006 | 11:54 AM
973604x4's Avatar
04.5 EZ doesn't do boost fooling....03-04 did with the elbow...but not 04.5+
I used to have an EZ....I sold it to my buddy on here (SPEEDSHIFT)...he runs Smarty, EZ, and a Quad Boost fooler with good results (except his clutch gave out)
Old Nov 13, 2006 | 04:49 PM
doug60's Avatar
Yes three pos. toggle in cab 25/45/65
ziggy
Oct 5, 2010 08:51 PM
Torque master
Nov 24, 2008 07:05 AM
budsowner
Aug 27, 2007 08:05 PM
redhornet
Jun 14, 2007 08:53 PM
T & T
Mar 2, 2007 12:27 PM
