boost elbow clamp removal
Old Mar 3, 2008 | 04:35 PM
RJ285's Avatar
Maybe I'm an idiot, or I was really tired last night, but I couldn't figure out how to get the clamp off of the hose between the waste gate and the boost elbow. I have an adjustable one to put in, and the instructions say the clamp is removable, but it looks like it is crimped on and I have to break it to get it off. How do you remove the clamp without breaking it?
Old Mar 3, 2008 | 05:03 PM
John Faughn's Avatar
If its the style I'm thinking of , there are special pliers that grab 2 edges & pull together in middle , I got to a point , after buying a couple different style of pliers .
On the flat part , just past the crimp , where the end overlaps , a series of holes , this is where the clamp grips itself for the crimp , put a small straight / regular screw driver under , to pry away from grips underneath , to put back on , you need to use a small needle nose plies to straighten out the crimp from a C shape to a U shape , making sure to have the catches at an angle that will catch , put back together as snug as possible , then pinch the C to a U shape till tight .
Old Mar 3, 2008 | 07:10 PM
MikeyB's Avatar
I was able to remove the hose with the crimp still in place. Slowly pull and twist at the same time should do it.
MikeyB
Old Mar 3, 2008 | 07:13 PM
homewrecker's Avatar
I just cut them off and use a regular style hose clamp.Side cutters work great.
Old Mar 4, 2008 | 11:00 AM
RJ285's Avatar
Thanks guys. I'm just going to cut the bloody thing off and replace it.
Old Mar 4, 2008 | 12:40 PM
Billm2004's Avatar
just cut it off, hose clamps are cheap to replace
Bad Ramer Jamer
Dec 27, 2007 09:32 AM
pwirch
Feb 24, 2007 10:31 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
Big Bob
Apr 3, 2006 01:32 PM
Stinkyz
Nov 12, 2005 08:26 PM
