boost with bully dog
did a search couldnt find what i was looking for....
does the bully dog triple dog change the boost levels? or just fuel maps??? i have the bully dog monitor and it only shows about 22psi of boost max, on all settings......
also the truck just doesnt feel as fast as it should/could be... i guess?!? i do have 35s on it now..... it just doesnt feel much of a change between stock and performance....
sorry for all the stupid questions....
thanx
chris
thanx
chris
thanx
chris
thanx
chris
then I dont think somethins right. I think with just bddl I can hit mid 30's and it is definately different than stock even with 35's
The bully dog doesnt do boost fooling. You need some sort of a box that does do fooling for the boost to go up.
That being said i hit 48psi daily with crazy larry and a boost fooler.
Yes, I know my turbo really hates me but i dont care.
get you a Quad boost fooler ($70 bucks), you will see right at 40 on stock turbo... before the boost fooler, I was only seeing 34-36.... makes alot of difference and lowers EGT a small amount.
i mean the monitor only shows 22 psi but it does feel like more...... i re-installed the program and can feel a bit of a difference..... maybe somethign didnt load right?!
what is the boost elbow? where do i find one???
The boost elbow restricts the air flow to the wastegate.
Here's where I bought mine.
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
MikeyB
MikeyB
MikeyB:
Did you install the elbow without a boost fooler? I ordered the elbow from the link you provided and went ahead and ordered a boost fooler from DTR.
Any idea on what kind of gains I will see from this with the Triple Dog?
if you have a boost elbow for an 03-04, no need for a boost fooler from Quadzilla.
So the 03 will not send error signals to the ECM? Out of curiosity why do they sell a boost fooler for an 03 than since you have to have the elbow to increase the boost with a stock turbo?
but why do you need more boost without a boost fooling, fuel-adding device on the MAP sensor?
