Blow Off Valve
Old Feb 5, 2007 | 05:31 PM
derek.mckay's Avatar
Originally Posted by 79warlock
You ment to say that it will not do anything for an auto, right?
Yeah...oops! Thanks for the correction 79
Derek
Old Feb 5, 2007 | 05:47 PM
Charlie8301's Avatar
yup, it's not worth the money for an auto, but would be nice on a manual
Old Feb 5, 2007 | 05:55 PM
you can here mine open at the end of the run in my pullin video
Old Feb 5, 2007 | 06:09 PM
Sounds REALLY good for preventing turbo bark, I think that I just found a reason for somebody with an auto to WANT to have one of those. When you are pulling a really heavy sled and get to the end, where you just can't pull anymore...you kinda tend to let off the skinny pedal really quickly so that you dont' start with the wheel hop and end up breaking something...so at the end of a sled pull, I could see it being something worth having on the truck...however, due to the fact that would really be the ONLY time it would really be in use, I still don't think it would be worth the money...unless my truck was sled pulling competitively on a VERY regular basis...
Derek
Old Feb 5, 2007 | 07:09 PM
baersmokers's Avatar
I Have Been Thinking Of Taking A Regular Blow Off Valve And Using That With A Vaccume Pump That Is Activated By A Micro Svitch On The Throttle Linkage To Activate The Vaccume Pump. I Already Have A Cheep Blow Off Valve And A Vaccume Pump Used For Rv's Sitting In My House But Don't Have A Way To Weld A Bung On To The Tubing. Otherwise This Whole Thing In Parts Is Under 200 Dollars. But Until I Figure Out How To Connect The Valve I Have No More Info.
Old Feb 5, 2007 | 07:21 PM
79warlock's Avatar
Didn't mention where you got the BOV, but most of them are designed for low boost gassers and will probable start blowing open around 20psi. And with your microswitch idea, how would you have the valve close as soon as the pressure is vented? Seems like you would have it open all the time at idle allowing unfiltered air in.
Old Feb 5, 2007 | 08:37 PM
RamWheelsBy4's Avatar
I have had the BD Turbo Guard installed for a while now. It does work on an auto, especially one with a custom 3 disc TC and fully built transmission. I barked my SPS66 almost anytime I was at reasonable throttle and had to let off, no matter how easy I tried. And for the times that you had to let off during acceleration, such as entering freeway and then some jerk pulls in front of you, barking was a sure thing. I don't think you can justify the cost on a stock truck, but in my case it eliminated all the barking during normal daily driving. It is expensive and requires someone with experience to install and tune properly, but I am glad I had one installed.
Old Feb 5, 2007 | 08:49 PM
Altered Image's Avatar
If you want to do it for just the sound why? Why would you want to sound like an import? When I think BOV I think turboed honda or subaru.Might be cool for a day or 2 but after that...
Old Feb 5, 2007 | 08:53 PM
3500lly's Avatar
When I hear it I think of 18-wheelers, that is a BOV I hear on them right?
Old Feb 6, 2007 | 12:32 AM
morkable's Avatar
I am thinking I would like it for when my truck goes into overdrive under moderate acceleration, or when I am pulling my trailer, and I am going up a hill, and it runs out of air,,, it would work for that wouldnt it??
Kevin
Old Feb 6, 2007 | 12:50 AM
t-boe's Avatar
Are you sure your not hearing the breaking system let off pressure? They do that even during acceleration.
Old Apr 6, 2007 | 11:42 PM
Desert Dually's Avatar
noob question
okay, what is "barking" the turbo? I'm not familiar with that phrase
Old Apr 7, 2007 | 09:11 AM
trik396's Avatar
There has got to be an easier less expensive way to allieviate the barking on these turbos...
Old Apr 7, 2007 | 12:54 PM
The only way I know of today is with the right foot. But even then driving like my 80+ year old father , still happened in certain driving situations out of my control.
Old Apr 7, 2007 | 02:09 PM
Mark1si's Avatar
I am thinking about installing one. Since I got the triple disk T/C and tranny done if I let off the lill pedal when it shifts man does that thing BARK like a scalded dog.
