Billet torque converter
If you do the flexplate, go with the one here. It will save you a few hundred bucks and will hold the power just fine. http://www.transmissioncenter.net/dodge.htm
As far as an input shaft, you don't need to do a billet unless you are going to be doing high boost 4wd launches or pulling heavy - 15k+.
If your running 37s and planning on playing in the mud I would recomend a billet input. If your spinning and then all of a sudden hook that thing is going to snap like a toothpick and possibly waste that 1200 converter you just purchased then have to pay $400 plus for a trans guy to pull it out and rebuild it and that $600-$700 extra dollars is a bit of insurance to help you sleep better at night imo.
You are going to need to do a complete rebuild more then likely b/c if you are anything like most members on this forumn your bands and clutches are toasted!!!LOL. Converter single is good for about 450-500hp and triple what you can throw at it, just depends on what you want to do with it and believe me you will get the power bug badly in the future im sure so you may just spend a few extra $ and go for the triple disc. Also a aftermarket valvebody, along with a center reinforced flexplate for billet one, along with billet input shaft, and most say performance bands and clutches but stock is better then burnt.
http://www.tcsperformance.com/cummins/
what about these. i am looking into one and a valve body now. what VB to go with. i was thinking BD.
lniemeyer2
Oct 24, 2012 12:11 PM
93dieselZak
Jun 16, 2011 06:10 PM
D45
Feb 2, 2010 08:05 PM
