Big Dually Tires
Big Dually Tires
Hey guys,
I have done some searching on the site and can't quite come to a conclusion. I want bigger tires on my 04.5 dually. Is it true that the biggest I can go without spacers is 285/70/17? If so, who makes an E rated tire in that size? Or can I just go with a tire with a high D rating? Thanks !
Shayne
Shayne
Originally Posted by HDBeauty
Hey guys,
Shayne
Shayne
I thought we could not fit 285's in the 3rd gen duallies? If we can, woohoo! I need tires bad and was about to settle on the stockers. I thought 2nd gens could fit 285's under the rear but we couldn't. I guess I'll wait to see how it works for you. I don't want to go spacers. I started looking hard into Rickson's.
It depends on the tire. I couldn't fit 265 70 17 Cooper s/t's on my rims without the sidewalls touching when loaded....1/4 inch empty. You need enough space so that rocks don't get wedged in and boom.
Originally Posted by Original Junior
I'm very excited to see this. Why hasn't others tried 285's on the 3rd gen dually?
I have 285's on my 03 there MT/R's so they have pretty good side lugs. I did run them without a spacer at first with no rubbing, but you have to watch tire pressure pretty close. Im sure with less agressive tires it wouldn't be a problem. Hope that helps some.
Nick
Nick
Nick
Nick
I have 285 MT/R's and they are super close w/o a spacer, and will rub when towing or with a decent amount of weight in the bed. A one inch spacer would be perfect with these tires, however I don't know where you could get some, or if they even make them. Two inch spacers are deffinetly overkill for the 285's, I just put a couple grade 8 washers on each stud between the wheels, has worked out well over the last 60k miles.
As RatherBeMuddin said they are super close, maybe an 1/8" space with them aired up pretty good. I ran them for about a week with out a spacer but it was to much of a hassel so i threw some on just to be on the safe side.
Yep, That is close. Too close for off road for me....one little pebble and two expensive tires gone at the sideway. Washers are an idea but the tire shops definitely won't do it. I scale so 1/4" won't pass inspection. ks
This sucks. I was hoping for a taller tire.
