BHAF install......
Old Oct 4, 2005 | 06:01 PM
hump's Avatar
BHAF install......
[IMG][/IMG]
Thanks for all of the information that you guys provided reference to install and where to purchase the filter. This site rocks
HUMP
Old Oct 4, 2005 | 06:16 PM
Dodgezilla's Avatar
Now you just need an Outerwears cover so you won't be scared to drive through some water....
Old Oct 5, 2005 | 01:51 PM
tslewisz's Avatar
Looks just like mine 'cept I put the air temp sensor in a different place.
What's the source for the Outerwear's?
Old Oct 5, 2005 | 02:30 PM
Dodgezilla's Avatar
www.outerwears.com of course..
Just kidding...
Old Oct 5, 2005 | 04:25 PM
whatdieseltoget's Avatar
Where did you get that setup? Does a setup like this increase airflow over a stick modded box? Seems like these will get more hotair than the stock box.
Old Oct 6, 2005 | 10:01 PM
whtractor's Avatar
how do you like it and is their any change IYO.
Old Oct 6, 2005 | 10:35 PM
hump's Avatar
whatdieseltoget, I got the idea from looking at posts on this website and DieselRam.com. As far as the actual parts, I ordered the filter over the net from www.fleetfilter.com #42790 for around $30.00. Then went to the local 84 lumber store and purchased the rubber adapter, pvc pipe and the clamps for an additional $20.00. Did the install myself which took about 45 minutes.
I read several post that stated the BHAF does flow more air than a modded stock air box. I can't confirm the actual numbers but I can tell a difference once the BHAF was installed.
whtractor, I love the BHAF. Just something about raising the hood of a Dodge diesel and seeing that big ol filter sitting there. Looks good IMO . As far as any changes, I have only had it installed for about 3 days now, but yes I can tell a difference in performance/throttle responce. Seems to be a little more snappy in the throttle. Sound wise, I don't think it made all that much of a huge difference in the turbo noise. I can hear the turbo spool up, but it's not annoying by any means
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
Mechanos
25
Oct 21, 2004 02:50 PM
WJB
Apr 15, 2004 01:49 PM
phox_mulder
19
Dec 24, 2003 02:22 AM
