Better to stack with TST? Edge EZ or Van Aken?
Old Sep 28, 2005 | 04:31 PM
whatdieseltoget's Avatar
Wha is the better stack in your opinion for an 05 6 speed? I am going to get the TST Powermax down the road here, and i want to buy either the Edge EZ or the Van Aken box now. Which do you reccomend? Are they very similar?
Thanks.
P.S. If i run the EZ or Van Aken by itself for a while, what gains, hp and mpg +/- am I looking at?
Old Sep 28, 2005 | 04:58 PM
bigman's Avatar
From what i understand the tst works really well with a little rail pressure so i would say the ez would work nicley. The van aken box does timing and duration, which the tst doesnt need any more of. I am sure others will chime in on this one.
Old Sep 28, 2005 | 06:44 PM
Rod meyer's Avatar
I'm pretty sure the Va does NOT do timing. Only duration on the c3.2 and only pressure on the c3.1 which would work good with a tst box.
Old Sep 29, 2005 | 09:39 AM
cquestad's Avatar
The VA C3.1 will work better than the EZ. Much better off the bottom. The TST does not need much help on top. A Ramifier set at 50% or the Ramifier with the "special TST" program on 100% will work the best.
Old Sep 29, 2005 | 06:37 PM
W.F.O.'s Avatar
So what kind of numbers r we talkin bout TST twins vs TST twins & ramifier stacked?
Old Sep 30, 2005 | 09:42 AM
cquestad's Avatar
With the right Turbo/Turbos, intake, exhaust, and fuel supply...
I made 550/1050 without exceeding 1450 EGT. It could even be more if you don't mind a quick spike in temps. Way more with twins...
SmokinDodge12V
Mar 21, 2007 11:02 AM
Andrew k
Jun 5, 2005 08:58 PM
gdh11
Jun 4, 2005 04:26 PM
ram350013
Apr 29, 2005 08:59 PM
Body Mechanic
Mar 16, 2004 02:04 PM
