Best way to debadge??
this is a chase it down answer.
type the word "vinyl' into the search engine. you will come up with a thread about something I can't remember...sorry. the thread then goes onto to discussing blacking out the b-pillar with vinyl and in this thread someone gives some great tips on debadging.
We don't need no stinkin badges
Don't tell anyone but I work for the company that makes the stuff behind the emblems.
MY 07's badging has got to be the ugliest I have ever seen
and they are all coming off in the spring.
I will check with the tec guys tommorrow to see if they have a recommended method for removal but in the meantime I will say they do not like to be too close to a pressure washer held nearly flush with the body panel.
and they are all coming off in the spring.I will check with the tec guys tommorrow to see if they have a recommended method for removal but in the meantime I will say they do not like to be too close to a pressure washer held nearly flush with the body panel.
i used a piece of spyder wire fishing line and kinda sawed it behind the badge then used a dremel with the buffing wheels then whiped it off with some goof off. tailgate looks great door badges are next.
I only removed my "big horn" badges, but I just pulled those right off and I used the liquid 3M adhesive remover from the automotive store. It is in a little square container, like the older metal paint cans, but pint sized. Soaked a rag with that, held it on there for a few seconds, and it wiped right off, then I washed and waxed it.
One more problem. In certain lights you can still see the outline of the letters. I've gone over it with the eraser wheel and polished it with the DW849 and a light polish. There isn't anything "on" the paint. It seems to me that the paint needs to see the light of day for awhile to possibly cure. If it doesn't I think I'll try to compound it, but if it's in the paint and not the clearcoat I think I'm SOL.
