best value monitor,tuner
Old Nov 15, 2011 | 10:38 PM
Spooler's Avatar
It's a box tuner. So it plugs into the map and RP sensor. No info comes from the OBDII port. This is before the Adreline type boxes Quad came out with.
Old Nov 16, 2011 | 12:32 AM
Ackerdiesel's Avatar
I read rail pressure with my cts one connection to the obd2 under dash
Sent from my iPhone using Tapatalk while not driving
Old Nov 16, 2011 | 10:26 AM
PWong's Avatar
So cts can show rail pressure by just plug in the obd2 under dash?
Is cts suppose to work only on "07.5 and up?
Old Nov 16, 2011 | 07:56 PM
You are correct... And everyone says stuff about only being able to read rail pressure on an 06 thru a monitor but I do it with my cts and know a boy that does it with his outlook on an 05
Old Nov 17, 2011 | 08:09 AM
PWong's Avatar
Ackerdiesel:
So you can read the fuel rail pressure, trans temp and turbo boost from your 2004.5 with the CTS hooked up to the OBDII port?
I am considering the Insight CTS for my 2005.
Old Nov 17, 2011 | 09:00 AM
staarma's Avatar
Originally Posted by PWong
Ackerdiesel:
You might want to call on that. 06 and newer for trans temp only. Data is really hit and miss on the 03-05 trucks. Be sure what you're buying will do exactly what you want. Also, make sure they do it how you want.
Old Nov 17, 2011 | 07:36 PM
JLee's Avatar
Even if I had to hook all the sensors up to get all the read outs I would be fine with that. I wonder how controling the computers really are in these trucks my 04 lost a fuel pump and wouldn't start but after trying to get it started the the only code it showed was low batteries! But my 05 will get the light when fall rolls around and temps get cold that says the air coming in is cold! Maybe some analog guages and a smarty then buy a code reader for when you do get codes?
Old Nov 17, 2011 | 07:42 PM
JLee's Avatar
I have heard a lot of good about the cts and the bully dog
nitis
Feb 26, 2007 07:38 PM
NJMurvin
May 10, 2004 06:00 PM
furious70
Apr 16, 2004 07:45 PM
peteygirl
0
Mar 14, 2004 09:10 PM
