Best twins setup
Old Jun 7, 2011 | 11:34 AM
mcolectd's Avatar
Best twins setup
Alright, looked into this quite a bit awhile back but have been busy and kinda leaving the truck alone, but Im starting to get the itch again. So, my question is, what is everyone's opinion on the best twins setup for daily driver with lots of towing. I tow quite a bit, everything from horsetrailers, to boats, hay, skid steer, tractor etc. Anywhere from 2-20plus thousand pounds. I'm most likely gonna go with F1 120hp injectors, and would like the best setup for quick spool up, good boost, and low egts while towing. Looking to be around 600hp. Let me know what yall think. Any help and ideas are appreciated.
Thanks
P.S. this is for the 06 dually in my sig
Old Jun 7, 2011 | 12:48 PM
spooled05's Avatar
If all you want is 600 you dont need anything bigger than 90 h/p injectors and id look into a stockr over 475
Old Jun 7, 2011 | 09:07 PM
Sevir's Avatar
i second the stocker over the s475 or s400, another option is the arctic air twins from relentless diesel. I think that is the setup i will be going with.
Old Jun 8, 2011 | 09:07 AM
BIGDAN65's Avatar
i have 62/65/12 over S475 I made 603.5 with 80hp nozzles. Spools fast and not smokey
Old Jun 8, 2011 | 03:13 PM
soulezoo's Avatar
DTR 1st Sergeant
To the OP's thread title....
Mine!
Old Jun 11, 2011 | 04:48 PM
Big Swole's Avatar
"Swole It like ya Stole It"
For towing and all around driving.. I will 3rd the Stocker over an S475..
Good friend of mine has this setup and LOVES it....
He raced it last night and tows regularly too....
Here a couple vids of his truck and setup...
Mike and I last night.....
http://www.youtube.com/watch?v=Y_PSg5s00SM
Later in this vid you'll see Mike truck and under the hood with the stock over s475..
http://www.youtube.com/watch?v=AoqXpSOZcCQ
I like this setup too for you're level... The little bigger turbo on top (secondary) will be better if you ever wanna go up a bit from 600...And will still spool great...
Old Jun 12, 2011 | 11:49 AM
mcolectd's Avatar
Ok thanks y'all I appreciate it. That's what I was originally thinking was stocker over s400. Whats the difference in the s475? Is mpi still the best way to go for this setup? Anybody know bout what it runs? The only reason I was thinking 120hp injectors is cause I know I won't be able to stop at 600 and will eventually probably want some more. But might just start with 90s
Old Jun 16, 2011 | 08:01 AM
Jason_K's Avatar
I've dynoed 668hp 1205tq with my wicked diesels stocker/s474, 120hp injectors, stage 3 cp3, and smarty tnt/r. My EGT's are awesome with the 120's so I would reccomend them over the 90's
Old Jun 16, 2011 | 10:00 AM
AH64ID's Avatar
Garrett BB twins.. GTX3582/GTX4294, with an external gate on the GTX3582 would be a supreme towing setup.. The Stage 2 Powermax would also make a great top turbo!
Old Jun 17, 2011 | 06:58 AM
Crazy Diesel's Avatar
How much power can a guy run before loosing it's daily driver capabilities still being able to pull? Also when you get 600hp and higher with bigger injectors what is your mpg like? I'm toying around the idea of doing something as stated above
Old Jun 20, 2011 | 01:16 PM
mcolectd's Avatar
Ok thanks a lot yall. I'm gonna look into doing this soon. Also, who makes the best intercooler for the money between banks, spearco and hellman? I'm pretty sure I'm gonna go with spearco, but just checkn.
Old Jun 20, 2011 | 03:49 PM
Spooler's Avatar
Get an HTT intercooler.
Old Jun 20, 2011 | 06:48 PM
Big Swole's Avatar
Save that money.
My stock IC is doing just fine at 70+psi with twins and 850hp.
Not saying the aftermarket ones dont make a bit of dif., just saying that lofs of high hp guys still use stock without issue.
Old Jun 20, 2011 | 07:28 PM
Spooler's Avatar
Your right. He dosen't need it but if he wants to spend his money I would go with an HTT probably.
Old Jun 20, 2011 | 08:16 PM
BIGDAN65's Avatar
I ended up with a Banks got it used for a good $. It was one of my attempts to cool the egts before twins. It did not drop them just took a little longer to get hot. I think you can make the power you want with the stock one
