Best stack for smarty
MikeyB
stack
I still have not got around to updating my Smarty to current software. You were helping me with that on the other forum. I am headed home for easter & might have a stab at that. I will PM you on the other forum if I need your help.
thanks....dave
Mid year 2006 and up cannot run the TST. 03-04, TST is the most effective stack. 04.5 to 06.5 TST is still a good stack, but not as effective (read: lesser amounts of power gain) as it is on 03-04.
Smarty and TST R49 so equipped (it is an option) can both manipulate pressure. For some reason TST does not like modified cp3's (it wants to surge), which, if you are at the power level you want to stack, then you are in the power level that it becomes necessary to have a modified cp3 so the TST version does little good. The Smarty will raise pressure; however, it will only do so up to the limits of stock. (roughly ~24.5k psi) Which brings us to:
Pressure boxes.
There are a few good ones out there. MP-8, edge ez, Quadzilla (forgot which model is pressure alone, but I think all his tuners have it), Dr. Performance, Diablo Power Puck, Banks six-gun and etc... Van Aaken is out of business, so I'll leave them out of the discussion, not that it wasn't a decent product-- it was-- but there are better boxes now and I would rather see you get something that is factory supported.
The thing you need to know about pressure boxes is that continuous use of them, especially at higher levels, will shorten injector life. More so on 04.5 and up than 03-04, but still, they will be more damaged over time. The higher pressures, especially if water or other contaminents are present, contribute to erosion within the injector (without getting into the specifics of what, which is an entire thread on its own) that will cause premature failure.
I am of the opinion that pressure boxes should be left in the off position for daily driving and turned on only for the track, dyno or the need to pass someone on the hwy... then turned off again. In other words, use them judiciously and sparingly!
Re TST stack
Thanks soulezoo my truck was built apr 06 is ther a pressure box out there that you can turn on & off while driving. I plan on building this truck to 700 -800 hp either going with MPI or Wicked twins any other tips welcome.
As mentioned, be careful of pressure boxes. If ran improperly they have been noted for eating injectors and if stacked with the Smarty and used improperly, can melt a few pistons. Use them wisely.
