Best fender flares
that is what i was wondering, i also wonder how much it would be to paint those babies, there pretty big
The fenders were not exactly a easy change over. You have to prefit and drill for the fastners, the stock inner fender liner needs cut and replaced with new plastic. Fiberglass does not fit as nice as metal so in areas like the bottom near the door the lines are inconsistant.
The bedsides are the outer shell, you will have to peel the rivet welds and seperate.
Body work and paint 800.00 for two fenders
Install and slivers 6 hrs
They look great and serve the purpose for me fitting 37" tires was my objective. I have a small suspension lift so the glass opened up some room.
By days end there should be some images in my gallery.
onetun
Onetun, thanks for the reply, it's good to get some first hand info on them. They look awesome from where the pic was shot. Hopefuly the lines aren't too bad at the mating edges up close. Sounds like the back could be a real pain you know where.
53 ******,
I like the ATS flares on your truck. How much coverage do they provide? What color are they unpainted? I prefer a dull/satin black color.
Thanks,
AlK
Thanks,
AlK
I hate to keep bumping this topic, but can someone tell me if there is any paint protection behind these ATS flares. 3 posts above this one it says they use no rubber, so do they use tape? If you have these flares please chime in. I really hate to install something that'll tear through the paint and possibly lead to rust. Thanks everyone.
in the end the rubber seal may be worse then no seal because then there is a tight edge for the dirt to work into.
all the fender flares I have sen have double sided tape to hold them on and then tie into the factory fender well mounts.
here is a pic of my ATS when the tape came off the bottom part(warranty) you can see up above how tight it fits to the body, but still not touching the paint.
I did not like my ATS flares at first because the tape came loses on them it was probably installer error because since they re stuck them they are great
that help or do you need more
sorry I don't have a straight down the side shot
My truck had a chrome fuel door on it when it came into town, told the dealer I wasn't paying for it, they took it off and painted a factory door and it's no where near close.
As far as having them pre-painted, be warned it might not be a perfect match. A friend runs a body shop, painted my grill to match, he said there's actually 5 different mixes for my Atlantic blue.
I'm sure ATS has it figured out by now.....
Am I the only one on the broad with ATS flares???? I am surprised that no one else chimed in about the ATS.
Glad I could help Guys
