best 64mm turbo
Old May 18, 2008 | 05:06 PM
  #31
blwnsmke's Avatar
Originally Posted by 04DEEZELRAM
Your goin to need injectors to help spool that thing now
Yea I hear ya!!
Old May 18, 2008 | 06:53 PM
  #32
Tacsavage's Avatar
Here is a run I made at Mopar at the Rock. This is showing how it launched and spooled, it is a six speed so almost no boost. I even red lighted, the first time ever, I have always left on the last yellow, but it got me with a -0.028 reaction time. This is the 64/65/13ss, Smarty 4.11 and TST. I had the temp. limit set too low so it defueled before the end of the 1/4, so that is why it isn't a good pass. The black truck is a hopped up SRT10. Tac
http://www.youtube.com/watch?v=S4CJhFs5T4M
Old May 18, 2008 | 09:01 PM
  #33
blwnsmke's Avatar
Wow that didn't look bad at all lag wise!! You said you launched on no boost in that video? You running stock injectors? What settings do you run? Whats your EGT at 1/4?
Old May 18, 2008 | 10:11 PM
  #34
04DEEZELRAM's Avatar
jeff just buy that turbo and get it over with
Old May 19, 2008 | 04:37 PM
  #35
Tacsavage's Avatar
That is stock injectors and cp3. With a manual, it is difficult to build any boost when coming of the line. I was reving the engine to about 2500 rpms That was Smarty 4.11 on level 9, TST on either 2 or 3, 0 torque, and rail pressure from TST about 5. End of the quarter egts were about 1450.
With stock turbo and towing my bass boat with Smarty on level 7, I would easily hit 1500deg before the end of the ramp getting on the interstate. Now with the 64/65/13ss, the same type run I can't even get 1400. So it cools well. Hope this helps.
Old May 19, 2008 | 07:47 PM
  #36
OT-OF-Here's Avatar
Htt Ss
That good eh??
Yep! And mine are twins! This truck rocks from a stop.
Old May 19, 2008 | 08:35 PM
  #37
cgmorgan06's Avatar
Are you running the 65 or 71, and a 74 or 80 on the bottom? What size fluxs are you running?
Old May 20, 2008 | 08:20 AM
  #38
RowJ's Avatar
BLWNSMKE - Be cautious about advice from members with manual trannys (no offense guys).
The automatic is a totally different animal! Most members have not driven both to fully understand the differences.
TNLoneWolfe, post # 22........ and Spooler, post # 26, are right on.
In 2004 I went to a HX-40/HX-55 Hybrid (basically a 64/72/14) and hated the slow spoolup. With big injectors and a TST box I was a smoke machine below 20 mph unless I turned the box off. The newer turbos you are looking at are much better at spooling up than what we had to work with 3-4 yrs ago, but be warned........ too big is no fun to daily drive with an automatic tranny!
RJ
Old May 20, 2008 | 11:01 AM
  #39
Gary Emerald's Avatar
Originally Posted by RowJ
Everytime I talk to someone with an II 62 or 64...it's a total love affair!
I just don't know the HTT well. I'm impressed with their company...the one time I sp with Paul(?).
I love their 2nd Gen Manifold. Been a winner for me!
If they are working with the lattest Borg Warner S300's, should also be great?
RJ
they are essentially one in the same, but I prefer how II sets up their wastegates vs. HTT. I think they crack open a little later yielding better spool up at a given max boost level
Old May 20, 2008 | 02:46 PM
  #40
blwnsmke's Avatar
RJ
Thats exactly what I was looking out for.. Jeez this is a hard decision
Old May 20, 2008 | 03:09 PM
  #41
homewrecker's Avatar
I have ran the 65 and 71 wheel on a 62 with a manual trans.There is definitely a noticable lag going to the larger 71.Can't say I have much seat time in an auto but if they are slower to spool a turbo than the manuals I would stay away from the 71 for street use.
Took a ride in my friends truck the other day.He has the 62/65/13 and I could really tell the difference between his and mine.(both manuals)Much quicker to build boost.We haven't raced but I feel sure he would eat me up the 1st couple hunrdred feet!Now on top end, thats another story.
Old May 20, 2008 | 03:55 PM
  #42
RowJ's Avatar
If it were me, I'd do the 64/65/13.... and live with a bit warmer top end.
Single turbos (all turbos actually) are a compromise. Remember you spend 99% of your driving time at less than WOT! And 3rd Gens handle the higher EGT's a lot better than 2nd Gens. JMO
RJ
Old May 20, 2008 | 05:10 PM
  #43
Spooler's Avatar
We lead you to the water now DRINK..........LOL
71 wheel on a 62 is barable driving empty but somewhat smokey if you stab it from a stop. I had help setting my truck up with the TC and already have 4.10 gears with stock tires. I do pull heavy and it does get hot starting out but once going it is O.K. I would go with a 65 wheel if I were you. I bought my turbo new/used so to speak knowing I may not like it but with HTT that can be fixed. So far, I can deal with it. I haven't pulled with it yet with the Smarty. We will see how I like it after that. The Smarty fuels more down low that is for sure, hence the smoke. We shall see.
Old May 20, 2008 | 05:18 PM
  #44
Mike D's Avatar
I daily drive with a 64/71/14 on my 2nd Gen and love it. I have a pretty tight TC to boot. I think it spools better than my old 64/65/12! Major reduction in EGT when racing.
Old May 20, 2008 | 09:43 PM
  #45
if you decide you want to go to a 65mm turbine, I should be able to accomodate. I'm getting an HTB2 rebuilt as we speak
