BDTD questions...smoke and popping
Old Aug 20, 2006 | 06:20 PM
rockittboy's Avatar
first off...is it true that no matter what setting ( tow, perf., extreme) you have your outlook set to, the truck is only running on whatever program you dowloaded with the triple dog? second. with the outlook on extreme and the BDDL set to extreme, i get a muffled POP out of the exhaust if i go WOT...is this lack of fueling? second with the BDDL set to performance and the outlook on extreme i only get about a 6' puff of smoke if i step on it from almost a dead stop. if it has 10psi of boost or more i get NO smoke. i have a BHAF and 5" str8 pipe dumping out under the cab. im just curious as to weather i am not getting the full performance because of a lacking fuel system? am i not smoking because of the freeflowing intake and exhaust? truck runs fine, hauls butt when i step on it even with 3.73's and 37s. just curious if anyone else had either the popping or lack of smoke with this intake and exhaust. thanks
Old Aug 23, 2006 | 04:22 AM
RAustin's Avatar
popping
At what rpms is it popping at. i have had the same problem with mine i have a 03 3500 dually 2wd 6spd with 373 rears straight pipe and afe cold air intake.i was told that is is defueling but i am still trying to find out myself
Old Aug 23, 2006 | 01:15 PM
judge88's Avatar
lack of fuel pressure. typically the popping is low rail pressure. i dont think just the bully dog alone could drain the rail on extreme with a good lift pump. i like fass but there are a bunch of options now on good pumps. these 3rd gens are picky they like there rail pressure. low rail pressure will cause alot of headaches when tuning these truck ask me how i know .
Old Aug 23, 2006 | 01:17 PM
973604x4's Avatar
exactly my guess....drained fuel rails. Get a FASS or another aftermarket LP.
Old Aug 23, 2006 | 05:27 PM
KVD's Avatar
KVD
Would just a walbro 391 w/ the factory lift pump be enough???
Old Aug 23, 2006 | 05:55 PM
cquestad's Avatar
To blow the factory fuel filter cap off...
You need the whole system...bypass included.
Old Aug 23, 2006 | 06:39 PM
KVD's Avatar
KVD
Do what???
Can I just dump the factory lift pump, run a walbro 391 and be safe, some one explain.
John93CTD
Feb 8, 2013 07:41 AM
65fury
Apr 26, 2010 06:59 PM
phantom 309
Mar 18, 2010 12:02 PM
MNorby
14
Apr 20, 2006 12:37 AM
Dave88LX
Dec 11, 2005 08:18 PM
