BDTD problem?
Old Jan 24, 2008 | 06:26 PM
cconrad331's Avatar
BDTD problem?
I have the triple dog with outlook monitor so I can defuel when egts get high, trans temp., boost, etc... but I am having a problem with my truck cutting out when accelerating WOT. Could this be my outlook defueling to cause such a miss and jump? I wounder this because it does it on performance and even more on the crazy larry setting. My rail pressure never drops below 16 or 17 thousand according to outlook but my EGTs peaked and 1341 and defuel is set at 1300. Any suggestions or comments, am I on the right track?
Old Jan 24, 2008 | 06:28 PM
MOJO1's Avatar
Your on the right track 1300-1341 it will defuel sound like whats going on.
Old Jan 24, 2008 | 06:37 PM
cconrad331's Avatar
I thought maybe it was defueling but it is a miss and jump that almost throws you against the steering wheel. I also had it throw a code once the other day (p2509) but it hasnt done it again yet. I did find a loose positve battery cable.
Old Jan 24, 2008 | 07:29 PM
smoky05's Avatar
set your defuel to 1500. you can peak that but dont hold it there for a long period of time. my dads mega cab sees 1700 peak alot and he has no problems
Old Jan 25, 2008 | 09:30 AM
Bud Kunz's Avatar
Watch your outlook when it happens. Can you see the power level on the left side go down? If so that's probably what is happening.
Where is your pyrometer probe located? Pre or Post Turbo?
Old Jan 25, 2008 | 10:26 AM
MOJO1's Avatar
smoky05, Your dads truck sees 1700 deg, MAN thats cooken I did that one time scared the you know what out of mei had low boost and didnt know it till later while DYNOING.
Old Jan 25, 2008 | 10:41 AM
cconrad331's Avatar
Buddy
Pyro is pre turbo and I havent noticed the power level dropping. Will it actually change from extreme to performance as it defuels?
Old Jan 25, 2008 | 11:51 AM
Bud Kunz's Avatar
Yes you can see the power level returning to stock and then when it cools down it will return to where you had it. Also it would help to have the version number off of it. That number is on the splash screen with the bullydog....3.something.
Old Jan 25, 2008 | 04:01 PM
cconrad331's Avatar
Buddy,
You mean off of the outlook. like 3.3.0???
Old Jan 25, 2008 | 04:15 PM
Bud Kunz's Avatar
Yes. If thats it, then we have a software update for it, if you want to send it in. PM me if your interested.
neverenough
Aug 12, 2006 05:12 PM
neverenough
Jul 26, 2006 10:16 PM
lightening ram
Jul 10, 2006 04:52 PM
ke5adb
May 25, 2006 09:30 AM
lightening ram
May 4, 2006 12:41 AM
