BDTD and abs/parking break light
Old Aug 30, 2006 | 01:20 AM
acook's Avatar
after installing my crazy larry with no tq mang. i noticed the abs light, and the parking break light came on, i also got the airbag light occasionally. I had heard turning the tq management of would do this, but i just uninstalled it to do some towing and they didnt turn of, checked to see what codes it threw and their was none?? Whats going on and how do i get the lights off?
Old Aug 30, 2006 | 02:53 AM
CrashCade's Avatar
Alright it sounds silly, But Start your truck and shut it of about 5 times. Then restart it and back-up for about 50 feet, put it in Drive and it should extiguish the lights. It is not a big deal.
That is BD Tech support fix.
Old Aug 30, 2006 | 04:04 AM
streetsmoker's Avatar
Weird as it sounds, Crash is right. I find the only time mine does it is if I dont cut the ignition off to recycle it, and just start it up after reflashing with the BDPP.
Old Aug 30, 2006 | 11:01 AM
acook's Avatar
Does it matter how long i let it run before i shut it off(i dont like shutting it on and off quickly)?
Old Aug 30, 2006 | 02:55 PM
Armapoc's Avatar
What version of Crazy Larry are you running? Maybe you should throw in the newest version from the web
Old Aug 30, 2006 | 08:27 PM
Actually I found just cycling the key without turing it over about 10 times then cranking it up and running in reverse does the same.
Old Aug 30, 2006 | 11:04 PM
acook's Avatar
allright thanks guys, ill give it a try tommorow.
BigBore050
Mar 9, 2010 11:46 PM
Stovetop535
Jan 8, 2010 12:47 PM
mr T
Feb 24, 2007 06:42 AM
mtl0727
Nov 19, 2005 08:14 AM
APD
Mar 4, 2005 02:04 PM
