Banks Six Gun
Banks Six Gun
hi
i can drive on level 6 with stock clutch?
i have 2003 ram with 6 speed manual six gun from banks.
and i have big head wastegate from banks.
wat is the maximum of boost with original turbo?
now i have 31 PSI Boost.
i can go higher?
Thanks
for answer
chris
i can go higher?
Thanks
for answer
chris
hi
original i have 25 PSI with Big Head now 31 PSI
i think that no problem. 40 PSi is the maximum.
i think the auto tranny limit the boost.
i have 6 speed.
you drive on witch level on your six gun?
i have 6 speed.
yes if have lot of diesel dudes here
thanks for answer i will test.
best regards from switzerland
chris
03 and 05 have differant turbos.The 05 will have more boost then a 03. I don't think 45 psi on a 03 will happen long before turbo dies.I'm not into the hotrodding stuff much but the 03/04 will not crank th boost a 05 or 06 will.
That is true, the 04.5 and up make more boost stock.
