Autometer gauges
Old Jul 9, 2005 | 03:37 PM
Kids Toy's Avatar
Autometer gauges
I installed the autometer Lunar gauges overhead and just like the instructions say attach the white power wire for the lighting to the dimmer switch.The problem is that they don`t dim,they flicker some then flash on off then all go out.Is it that the Lunars series are not suppose to be attached to the dimmer switch but to constant power(I believe that Luner may not have an actual bulb in them)I took all three white wires ,sliced together into one then into the OR/WH striped wire going to the back of the dimmer switch.That wire dimmed when tested.
Old Jul 9, 2005 | 06:39 PM
Buckshotmckee's Avatar
I have the Autometer Z-series and they are spliced into the dimmer switch with no problems dimming. It sounds like you have a bad connection.
Old Jul 10, 2005 | 08:32 AM
Blue600's Avatar
On my truck the dimmer wire is OR/BLK.
Old Jul 10, 2005 | 10:24 AM
trik396's Avatar
I have Lunar series as well. I connected to dash lighting - not dimmer. Lunar uses some type of phosphor coating to illminate the guage. Not a bulb. No dimmer required.
Old Jul 10, 2005 | 11:01 PM
Kids Toy's Avatar
Thanks Guys,I`ll be changing it as soon as I get a chance
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
Hardrider5
Nov 9, 2002 09:29 PM
