Asked while back, but question
Old Mar 7, 2008 | 07:42 PM
WhozNxtLS1's Avatar
Hey I asked awhile back if a smoke switch could be put on a truck that has a smarty jr. The answers I got were that you could NOT put a smoke switch on a smarty jr truck. However, I was under the assumption that if a box did boost fooling (I believe the smarty does) then a smoke switch would work right????
Old Mar 7, 2008 | 07:57 PM
vzdude's Avatar
DTR's 'Go to Guy'
The problem is......the Smarty just changes what the ECM will accept to see from the MAP sensor. A boost fooler will allow a smoke switch to show it it's max level. Without a fooler/ fueling box, the computer will see a direct short to voltage and defuel and set a code.
efilnikufesin
Jul 9, 2008 05:11 PM
Buffman88
Mar 28, 2008 07:09 AM
ouchman
Oct 20, 2003 11:30 AM
Ten_Bucks
Oct 10, 2002 01:33 PM
