Anyones quadzilla LP gauge read erratically?
Old Apr 26, 2010 | 04:55 PM
sallyman1's Avatar
sometimes my quad lp gauge will read a constant 14-17 psi because i have a FASS fuel system. but after a while of driving or city driving it reads between 0-9 psi. what is this? do i need a new transducer/sender and if so where do i get them?
Old Apr 26, 2010 | 06:15 PM
DaveB.inVa's Avatar
If this is the gauge that has both rail and fuel pressure I'm surprised its lasted long at all.
I went through 4 of them! I'd no more than get it installed and it would die within a few hours. I finally cut my losses and didn't try to get any fix or another gauge after the last one died.
I will say that Quad and his guys were always very helpful and would exchange them without trouble. It would've been a great gauge if it worked!
Old Apr 26, 2010 | 06:45 PM
walker1's Avatar
Did you have problems with their latest version? I've read the early ones were plaguedwith problems.
Old Apr 27, 2010 | 08:27 AM
butchera's Avatar
I've had mine about 9 months now with no problems.
Did you purge all the air out when you installed it? You may have an air bubble that is giving you the stray reading.
Old Apr 27, 2010 | 12:34 PM
dodgediesel's Avatar
Hey bud. I have a bunch of the older sending units. Let me know if you need them. They are new and you can have them. I have 2 - 30 psi ones and 2 - 100 psi ones..
Old Apr 27, 2010 | 06:33 PM
DaveB.inVa's Avatar
No, mine were all the older versions. I never went back.
I'd also like to apologize, I posted all that stuff and never in the least helped the original poster. Not cool.
Old Apr 28, 2010 | 02:16 PM
sallyman1's Avatar
ive had it installed for 4 yrs now. there still shouldnt be air in system. fass should take air out. also are the sending units new? could you send me a 0-30 to sask canada s0k 2a0?
Old Apr 28, 2010 | 04:49 PM
I thought you were in AB?
Old Apr 28, 2010 | 06:54 PM
sallyman1's Avatar
no sask. what do you want for the 0-30 psi ones? did they work with the quad LIFT PUMP gauge?
Old Apr 29, 2010 | 09:25 AM
They worked with the quad recon and my Commander. I upgraded to the new transducer. I don't want anything for them. They are sitting here collecting dust my friend. I will send you the 0-30 and a 0-100 just incase. PM me your full name and address.
Old Apr 29, 2010 | 04:54 PM
sallyman1's Avatar
thanks...what does the new transducer look like? will it work with my gauge?
scott saliken
box 3327
humboldt sask
s0k 2a0
Old Apr 29, 2010 | 04:57 PM
sallyman1's Avatar
i dont know why my sig says alberta..i dont know how to change it lol
Old Apr 29, 2010 | 05:11 PM
Fire Rescue124's Avatar
mine will go from reading 20-30 all the way down to 0-9 no matter what i am doing sitting driving city or highway. i used to be able to mess with the ground wire on it cause it is inline and that would fix it but not i can't get it to work right. but also my comander just flashes the fuel press as if it is too low. i can't get it to go back to normal with the other three readings. and the none of the buttons work anymore. looks like its time for regular gauges. does anyone run the new black comander? how long have you had it? how does it seem to work?
Thanks,
Eric
Old Apr 29, 2010 | 05:16 PM
scott saliken
box 3327
humboldt sask
s0k 2a0
I don't think it will work, you would have to call Quad for that answer. I will mail them out tomorrow for ya. If they work, buy me a coffee sometime....
Old Apr 29, 2010 | 09:41 PM
sallyman1's Avatar
thanks man...
