Anyone use the FS2500 oil filtration system
I am thinking about buying one in the next couple of weeks. They are a good company to talk to. Very informative about the info to. They told me that the kit comes with everything to install and the instructions are chassis and engine specific which is GREAT! The only thing that you would have to do is tap the valve cover for the oil drain back. When I get one I will let you know how it works.
I talked to the guy and the price for my app which is a 2005 Ram 3500 was 489.00 and 20 to ship. You will have to change the filter in the 2500 every 10,000 and the filters are 22 and some change a piece. Plus they will give you some places to send samples of your oil for them to analyze and that is how you would get your cycle. He also told me that some of his customers have gone up to 40,000 miles before changing the oil. When you change the filter you will have to put in 1 1/2 quarts back in the truck but that is it.
You should check out Oilguard as an alternative. Much less expensive. And looks to be the same filter system. I'm stacking Oilguard with a Motorguard setup afterward. This will possibly be the most overkill in bypass filtration, but that's the kind of guy I am...
btw- go to Bobistheoilguy.com and go to the bypass filter section. You'll learn more than you'd ever think you'd want to know...
