Anyone tried stacking a VA C3.2 w/ a DL?
Old Aug 1, 2009 | 08:47 PM
Dodgezilla's Avatar
I am currently running a Van Aaken C3.2 duration box. It works fine but I'm looking for a bit better off the line throttle response so I'm thinking about getting a downloader. Has anyone tried stacking this box with a Smarty, Predator, or BullyDog programmer? Will it be too much duration? I really don't want to have to shell out more $$$ for a pressure box if I don't have to...
Old Aug 1, 2009 | 08:54 PM
w.tx iceman's Avatar
I would bet a flashpuke would work well,don't think it has a lot of duration like the others you mentioned.
OT-OF-Here's Avatar
It shouldn't work,... and even may be harmful
Most of the high performance dl'ers are leaning heavily on duration anyway and adding more is NOT what they need. If you are going to run the VA C3.2 then your best bet is a nice dose of pressure, i.e. MP-8, Dr. P, EZ, VA C3.1 to mention a few.
Old Aug 2, 2009 | 03:13 AM
trik396's Avatar
I run the VA 3.2 duration all the time. I made the numbers in my sig with the VA on mid setting (70hp) with my Diablosport Predator on Extreme RKL with a spray of water for cooling. I tried running the high setting (130hp) but I only have stock cp3 and I don't think my pressure could stay up. Temps went wild and power was down. You really need a bigger than stock turbo to handle just the 3.2 by itself let alone stacked with a downloader.
Old Aug 2, 2009 | 05:54 AM
Dodgezilla's Avatar
If I was not worried about huge power would it be an OK stack though? My plan would be the run the C3.2 on the mid setting and the DL on a tow or performance tune keeping in mind that even though I'm doing this I'm not driving like a maniac since my trans is still stock..
Old Aug 2, 2009 | 06:21 AM
trik396's Avatar
As long as you stictly monitor your exhaust temps, you should be fine... Your trans won't last long if you hammer it either. I've run the Performance tune and the VA 3.2 on 70hp with stock turbo but NEVER floored it... maybe half throttle at best and temps would easily hit 1200.. I didn't go any further because I know I could probably hit 2000 with that stack/turbo. Throttle response is pretty darn good.
Old Aug 2, 2009 | 06:24 AM
Dodgezilla's Avatar
Cool. I have to find me an EGT guage still and definitely won't do it until I have that installed. I am full aware that too much duration=lots of heat...
Thanks man.....
And I don't know who I'm trying to kid. I need to start saving for a transmission.......
Old Aug 2, 2009 | 06:27 AM
trik396's Avatar
and remember that some downloaders run pressure also. Diablo does it all depending on what tune. Pressure, duration, and timing. I ran an Extreme RKL "PUFF" tune for awhile... it smokes at idle, hence the puff name.
Don't know much of what Smarty or others do to get their power.
Old Aug 2, 2009 | 07:36 AM
MikeyB's Avatar
I recommend something that adds timing. Smarty Jr might be a good choice since the lower setting is pretty much timing only. Use the VA as power on demand...
Hmmm, I wouldn't mind trying that myself.
MikeyB
Old Aug 2, 2009 | 08:37 AM
Dodgezilla's Avatar
Looks like I'm getting an unbelievable deal on a Predator that I can't pass up. I had one on my 07 and it was great...
Old Aug 2, 2009 | 08:42 AM
trik396's Avatar
Just make sure the guy goes back to stock before he gives it to ya...
Old Aug 2, 2009 | 08:48 AM
Dodgezilla's Avatar
Yup. Already took care of that concern....
03CTDCO
13
Sep 1, 2005 11:47 PM
marv h.
Aug 28, 2005 02:03 PM
squirrel
Jul 22, 2005 08:01 AM
CruisingRam
Aug 5, 2004 12:28 AM
Rob_OBX
Jan 13, 2004 10:07 AM
