anyone tried the MILEAGE MAX module?
If you floor it all the time it will be in stock mode. We watch boost and rail pressure and if you are flogging on the truck it will be stock power.
So, with that said you CAN hurt the tranny with stock power if you beat it to death. What I should have said is that it will not make it any easier to hurt the driveline??? You can break anything!!!!
What in the world are you driving??????? Can you fill out your sig so we can see what you have...what you've done to it...?
Its an 05 automatic 2 wd qc 3.73 no silencer ring guts removed from torque tube Quad commander Thunder road.Thats about it I try not to drive over 60 ,a little more sometimes. When I filled up last time I was really low on fuel DTE 5 Miles.
Joe
Joe
It is made to only be on where you can gain mileage and off where there is potential to get worse mileage.
That is the problem with most modules. You can get some mileage but, you keep wanting to dig a little deeper because they run so well. This eliminates the possibility of getting worse mileage!
Yes, it helps with towing mileage.
WE only revert back to stock when we see you are flogging on it. So at WOT and Full Boost you are not going to get any changes. If you tow like that it will not help. If you tow normally it is fine.
