Anyone running Dynomite Diesel Injectors?
Old Feb 22, 2006 | 05:26 PM
streetsmoker's Avatar
Hey, I just sent off my injectors today cause I couldn't pass up Dynomite's $300/set sale. So I was wondering what I should expect with the mods listed in my sig. I know honed injectors don't like pressure very much, so I don't intend to run the BDPP on extreme. But with the Edge on Lev.5/BDPP on Lev.2 I should be right at the power level i was with the stock injectors when I had the boxes on 5/3. Am I good in thinking this? Anything you guys can think of I may not know about would be appreciated. Thanks ahead of time.
Old Feb 23, 2006 | 01:51 AM
Syndicate's Avatar
I noticed my truck ran a bunch smoother at any rpm. My cold starts were much less smokey and of course it was way quicker. I just put in the Rokkteck sensor and it runs even smoother and makes a bit more power. plus the little bit of injector knock I had from the quad box is gone now.
Old Feb 23, 2006 | 08:35 PM
Thanks Syndicate. I hope there are some more people who can give me some 1st hand knowledge about the performance of these injectors. It seems everybody on here wants to steer you to a specific brand or type and say they are the best, but when you ask for 1st hand experience they all turn mute. I bet if my title read something like "Thinking of buying injectors, who's are best" people would jump all over it. By the way, what type of egt's are you seeing. Before/after injector install?
Old Feb 23, 2006 | 09:58 PM
runamuk's Avatar
WHAT??? $300.00per set??? That is off the hook !!!!
Give me a link please!!!
Rick
Old Feb 24, 2006 | 02:11 AM
Syndicate's Avatar
http://www.dynomitediesel.com/
Old Feb 24, 2006 | 07:25 AM
glowball's Avatar
Syndicate. You notice any mileage gains with the injector work you had done? I see you have a smoother running truck. I think my injectors are getting a little dirty. Thinking about heading up to Monroe and getting a little work done.
Old Feb 24, 2006 | 10:38 AM
MonroeDiesel's Avatar
Mine are great. truck runs very smooth and a little better gas mileage. I have not taken it on a long freeway trip yet but heading over to tri cities tonight. i will hand calculate this weekend
Old Feb 24, 2006 | 02:07 PM
Syndicate's Avatar
Ive changed my tires and not corrected my speedo as they were only slightly taller so I have not bothered tryin to figure out milage. It is a great mod. Very good bang for the buck and you end up with a better running truck overall. Plus they are a great bunch at DDP.
Old Feb 24, 2006 | 03:56 PM
Hey Muck. if you want them, you better hurry cause at the end of the month the price goes up the their normal of $750-$950 a set.
Monroe, how do you like that Super B turbo. I'll be looking to upgrade after I get my injectors and send off the Juice to get the "HOT" upgrade. When I do this, I'll be able to ditch the BDPP, and still get in the neighborhood of 475-500hp. Right now, on stock injectors and turbo with both boxes turned up I'm right at 425-440hp.
Old Feb 24, 2006 | 10:01 PM
Kman9090's Avatar
streetsmoker do you have any fuel system on your 03? I have an 05 with the same stack you have edge and bully dog and I can starve my cp3 for fuel. I only put down 357 hp with them both stacked I was running so low on fuel.
Old Feb 25, 2006 | 04:18 PM
No Kman I don't have an upgraded fuel system yet. I do have a slight starvation problem when both boxes are turned up but only during normal driving. Under full acceleration, I don't have any at all. I am in the process however of putting in a Walbro retrofit so I don't have to worry about this at all. I dyno'd with just the BDPP back in Sept. when I still had the stock tranny and no intake improvements and the #'s were 367hp/734tq. stock it was 264/490. I know I'm in the neighborhood of 425-440, cause when I had the BDPP the best times I coud pull in the 1/4mi. were 14.9 after adding the Edge, and building the tranny I consistantly pull down 13.7-14.1's. So if you do the standard of 20hp/10th sec. deducting a few hp as error factor puts me just right.
Old Mar 5, 2006 | 11:27 AM
Kanab Ram's Avatar
Finished installing mine yesterday. First impressions were very positive. Smooth power throughout. I opted for the 50hp but sure seems more
Old Mar 5, 2006 | 04:32 PM
Kanab what kind of pusher pump are you running? Are you only using the race box and injectors? What is the Quad Race Bow rated at? My 70hp set of DDP injectors should be installed Monday and I'll post a test drive report once they are in. I'm sure they will meet all my expectations.
Old Mar 5, 2006 | 07:51 PM
Kanab Ram's Avatar
<<Pusher pump>> I was running Piers' which is basically a Carter. That lasted about 40k miles. Now running a Holley Blue.
Yes, I'm only running the race box and injectors currently. The box has three settings (60, 100 and 130hp). I haven't run the truck on the race setting (130hp) yet since I installed the injectors (only city traffic). But the truck seems to pull a lot harder on the 100hp setting w/injectors, than it ever did on the 130hp w/o injectors. Ross at DDP said the injectors should combine well with Quad's box.
Old Mar 5, 2006 | 09:21 PM
So I take it you haven't been able to do a WOT run yet?
