Anyone know what a 05 speed will hold
Old Sep 12, 2005 | 07:10 PM
OldSmokey's Avatar
Anyone know what a 05 6 speed will hold
Ive got an 05 six speed and, Im just wondering if anyone know what the limits of this clutch are. Dont really want to replace the clutch again.
Old Sep 13, 2005 | 04:41 AM
katoiler's Avatar
Well they don't like the crazy larry and a TST!!
Old Sep 13, 2005 | 06:40 AM
rock's Avatar
I am pretty sure the clutch can last a long time (100K+) with stock power. When you plus up the power and not the clutch you are asking to "do it again". I hear that calling south bend for advise is a good idea. I haven't called them but I have read on this board that they are very friendly and can explain the best clutch for any applicable operation.
Old Sep 13, 2005 | 08:26 AM
nickleinonen's Avatar
SBC is working on a replacment solid flywheel & clutch for the g56 application. that will ditch the somewhat problmatic DM flywheel...
Old Sep 13, 2005 | 08:35 AM
South Bend Clutch's Avatar
Vendor - Former Vendor
Safely you can run the stock clutch up to 300-325 rwhp. Anything after that the clutch may hold but the life of the clutch will be cut down drastically. Driving style then becomes important.
Peter
Old Sep 13, 2005 | 09:52 AM
05mxdiesel's Avatar
TST quotes anything over 800 ft lbs. will slip the stock clutch.
Old Sep 13, 2005 | 12:20 PM
wap's Avatar
wap
is that 800lbs flywheel or rearwheel?
Old Sep 13, 2005 | 01:10 PM
toddbweaver's Avatar
I have the quad race box and my clutch slips on all three settings, including the 60hp in 5th and 6th gears when you have your foot into the peddle. I think the stock clutch will not hold virtually any power upgrades. I'm just waiting to get the money to upgrade. Maybe the 05's with the G56 will hold more, not the N5600 04.5's.
Old Sep 13, 2005 | 01:38 PM
YFZ's Avatar
YFZ
Old Smokey, not sure if you have changed your gears for the 315's, but as you probably already know that will have a direct affect on clutch slip...
Old Sep 13, 2005 | 01:50 PM
wap's Avatar
wap
Driving as hard as I can with my 05 I havent been able to get mine to slip yet on race setting barking tires hittin 4th with a dually and it is a g56
Old Sep 13, 2005 | 05:27 PM
staarma's Avatar
It's flywheel. People often misquote torque as rear wheel on a chassis dyno. The fact of the matter is that if you want to look at torque at the rear wheel, it would be a tractive force measurement. Torque is a calculated number on a inertia chassis dyno using time, distance and weight and measured number on a load (water, electric, hydraulic) chassis dyno using a load cell. Either way, it will always be flywheel because the RPM that is measured for the equation is taken from the engine. If it is an inertia chassis dyno the equation will be HP(which is measured) X the RPM / 5252 = TQ. If it is on a load (water, electric, hydraulic) chassis dyno then the formula is TQ (which is measured) X 5252 / RPM = HP
HTH.
BTW, with the mods in my sig., I haven't been able to get my clutch to slip one bit. (knocking on wood)
Old Sep 13, 2005 | 06:20 PM
Ramtough's Avatar
thats weird i have the race box and my clutch holds. even when i do a 130hp setting 4wd launch droping it form 2000 rpm. maybe my 4.10s are easier to turn?
Old Sep 13, 2005 | 07:44 PM
What really bothers me is I've been in 6th and wanting jump out into traffic and get up to speed real quick and even on the 60hp setting I've have to be careful or the rpm's just take off when I hit 2000. I was very dissappointed when this happened. So far when I'm towing I'm ok as look as I keep it below 2000 rpms. I guess I'll just wait to the cash comes in. I'm still really happy with my mpg's though. Last tank was 22.4 and I've had a high as 24.4 on a complete highway trip.
Old Sep 13, 2005 | 11:51 PM
triplenickel's Avatar
I can slip mine too if I really get on it in 5th or 6th on level 4 or 5.
etn550
Feb 2, 2014 05:04 PM
PeytonMaterne
Jul 25, 2009 12:28 PM
jeffs07mega
Feb 24, 2009 02:47 AM
tritont
31
Sep 1, 2007 05:03 PM
