Anybody made their own eliminator pipe?
From: Adirondacks of New York and Daytona Beach FL.
Re:Anybody made their own eliminator pipe?
We'll I could do that....but if someone already knows....all I have to do is go get the stuff! Not tear it apart and put it back only to tear it off again!
Makes sense to me.
I have to work outside and it ain't to hot right now!
Makes sense to me.
guys, do you see my post, PM mark thomas. He made some of them, and he`ll give you the dimmensions(sp). goto page thirtysumthing under members photo`s, look for "marks truck" he has pics of tho one he made. i have one on my truck, and i can really hear her sing
[quote author=roperdog link=board=49;threadid=22956;start=15#msg218605 date=1070634439]
dd361
did you remove your silencer ring?
mine is staying in because i do not want to lose any performance ;D
[/quote] yes i did, if you want to hear the turbo you should remove the ring. as far as LOSS of performance,i haven`t noticed any. all that ring is for is to make it quiet.
dd361
I spent a fair amount of time making a really nice polished stainless one
made the turbo sound good ;D
but
lost some throttle response and about 1mpg
so I went back and welded in a cross piece kind of like the stock one only without the baffles and holes
still sounds good and got my throttle response back ;D
dont know about mileage yet
IMHO, that little black thing does a lot more than quiet down things, it also keeps the air from spinning with the turbo
but
[quote author=Agades link=board=49;threadid=22956;start=15#msg221956 date=1071154671]
but
[/quote]
really???
i think the baffle is far too distant from the compressor to have any effect on turbulence into the IN side of the turbo.
the philosophy of the TAG (dieselpowerproducts.com) is what you are speaking of.
are you sure you didn't just have your "foot" into it more since it sounded immensely better? ;D
but
[/quote]
really???
you know I really thought in my mind that getting rid of that thing would be good for flow and all that
but I gave it as true of a test as I could (without a dyno)
I drove a 200 mile trip on sunday with the plastic and got 19mpg with the cruise on 62 mph
I drove the same trip on monday with the homemade stainless "eliminator" and cruise on 62mph and got 17.7 mpg and noticed a little less throttle response (not major difference but a difference)
I would really like to see someone with access to a dyno give this thing a real test to see exactly what it does effect
I dont think theres any difference in peak hp or torque but I noticed the bottom end change
I think this thing is dodges answer to the TAG
oh yah,
its extremely easy to make one if you have a small slip roll
the pipe is 6.75"long X 5.25"OD
FL = [OD - (1.333 x MT)] x 3.1416
FL = flat length
OD = outside diameter
MT = metal thickness
FL = flat length
Is this rolled type really sealed tight? If welded OK but with it being rivited together? Seems like dirt could migrate through there some how.? Any thoughts
[quote author=Hairy1 link=board=49;threadid=22956;start=15#msg222440 date=1071202088]
[/quote]
Hairy1,
You can run a bead of RTV between the overlapping seams before riveting the two pieces together.
MikeyB
[/quote]
Hairy1,
MikeyB
[/quote]
how do you think most tubing is made?
its rolled then welded at the seam.
why would you rivet when you can weld?
of course the rivets will leak.
[/quote]
I made mine the other day out of PVC fittings. I found these adaptors at Home Depot that connect 4" PVC to Soil Pipe. So I took two of these which the outside diameter is 5.25", I cut the ends off that are used to connect to the 4" pipe leaving about 3/8" to allow a surface to join the two pieces together. I did have to dremel those surfaces down where they needed to be glued since they were never meant to be together. Once I was happy with the fit I glued them together with PVC cement which literally melts the two pieces together so no leaks will be present. I them threw a quick coat of flat black engine enamel on it. It looks like it belongs there. The diameter is just about an 1/8" larger than the stock housing and all I had to do was loosen the hose clamps further and the rubber fits so good on there it almost doesn't need the clamps, but of course I clamped them down. When I get a chance I will post some pics.
