Anybody dyno w/ the Crazy Larry program
Just curious if any one has put there truck on a dyno with this program in it, if so what do you think compared to the TST or any other high hp box or programmer ?? Thanks, Mike
I believe that Piers said the Crazy Larry by itself with his street/strip twins and cam was 554HP.
Then he said Crazy Larry stacked with TST 7/6 put down 675hp
That would be ALMOST as good as sex.
.That would be ALMOST as good as sex.
PourinDiesel,
On second thought I think you are right. Sittin on 675 Cummins HP waiting for my slightest caress, might just be the ultimate adrenaline rush and provide way more satisfaction and gratification than normal old sex.
What thread did Piers say he put down 675hp? I did a search on TDR and couldn't find it.
The TST and Crazzy Larry sounds like a lot of timing to me.
Scratch that, I just now found the post.
Brandon
Brandon
Originally posted by Don M
The Dyno was a bit inflated! The same truck made 513 with a 6% correction factor using a TST on a DynoJet. Or 483 Raw uncorrected. He did not have the CLDL at that time.
Don~
Don~
Don~
Yeah, That's it, Piers doesn't know what he's doing.
Don~
Sleds,
With DynoJet being the dyno that 90 plus percent of people will dyno on...you can get a wildly different outcome using a TST and CLDL with other trucks when compared.
Only a few may show these huge gains with this stack because the CF and the type of dyno differ.
King,
What did you dyno this set up on the DynoJet?
Don~
King,
Don~
Don, I agree that all dyno's are differen't and correction factor is a part of figuring hp. What I don't understand is why you think the dyno-jet measures the correct hp from the statement you just made to my reply. The same truck and set-up could dyno on, I don't know how many dyno's, and get differen't results. Bottom line, piers showed what differen't stacks did for hp on the same dyno, same truck.
Agreed?
Agreed?
Agreed?
Agreed?
The problems dont arise until the next guy tries to make it happen for him and he cant make 600.
Don~
