Any pics of 305/70R17 Nitto's on stock rims and 2-3" Lift
Old Nov 13, 2007 | 09:21 PM
jgiachino's Avatar
Anyone have any pics...or similiar?
Thinking about a lorenz 2.25 system...obviously will need bigger tires....worried about going to 35" tires with 3.73 and dtt trans (want to minimize the perf hit)....so thinking a 305 will get me closer 34" x 11.5 wide (vs 35" x 12.5") but minimize the perf hit....
Will 305's rub on stock rims with 3" lift?
Thoughts?
Old Nov 13, 2007 | 09:48 PM
jamesbfishin's Avatar
Some guys are running 37's on stock rims with minor fender trimmimg, the 305's should fit fine. Post a review of the Lorenz system if you get it.
Old Nov 13, 2007 | 09:59 PM
z28fan's Avatar
hey man i just put 305/50R20 on my 2wd with a two inch front spacer and i think i can tuck 35'5 with minor fender trim so i think your ok
Old Nov 13, 2007 | 10:08 PM
onebadrubi's Avatar
I have an 07 mega cab 5.9l 4x4. I will be doing a 2" with 315 or 325/65/18 or 20 in the next couple of months. They shouldnt rub at all.
When you say perf hit you are saying a performance hit or actual power loss? This is my first deisel and I would not expect to notice a 305 except under heavy loads. I plan on the 35"s and a light programmer just to have fun playign with others.
Anybody know any good places to view some trucks with leveling kits and bigger tires?
Old Nov 13, 2007 | 10:52 PM
jgiachino's Avatar
Performance hit....trucks got plenty of get up and go....but the biggerr the tire, the more i loose....dont really want bigger tires, but want better suspension, and that necessitates a lift....dont want to spend the $'s going to 4.10 gearing which would keep the gearing very similiar to the way it is now.
firemansdiesel's Avatar
Thoughts?
You will feel a little power loss down low (taking off the line), but once your going I don't feel any loss (35" tire). Especially passing someone. My mileage stayed basically the same on highway from 285's (I only had my stocker tires on for about a month. So can't tell you the difference there). City driving you may lose 1-2 mpg. I don't do really any stop and go. So that does not affect me.
With the suspension system you want. 35" look real good on it. You may regret after going w/ the 305's.
On the rubbing issue. W/ 305's on stock wheels you should be ok w/ the upper control arms w/o rubbing. W/ 35" tires (especially Toyo's, because they are wider than most) you will rub your upper control arms w/ turning the wheel almost all the way or any articulation. All that comes down to is how tolerant can you be when rubbing. You will clear the wheel well w/o rubbing also. So no concern there. If you decide to upgrade the wheels (which you will in time ). Get a wheel that is atleast 5" of backspacing w/ 6" backspacing optimal w/ our Dodges. You'll clear your control arms and they tuck underneath great (similiar as stock) w/ 6" backspacing.
cumminsdriver635
13
Dec 13, 2008 03:22 PM
Death Dealer
Dec 11, 2008 10:40 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
LooseBoltsRob
Jun 14, 2007 02:13 PM
streetsmoker
Nov 30, 2006 02:43 AM
