Bad FCA symptoms????
Got a questions guys. Recently I been having an issue with my truck. Under light throttle (and around 1800rpms and again around 2500rpms) my fuel pressure will fluctuate erradically back and forth between the 20psi mark and the 30psi mark. During these jumps my rail pressure will sometimes (but not always) fluctuate from 18,000 up to as high as 22,000psi. It's not the guages because during these occurances the engine sounds like it is missing. Does this sound like a possible fca problem or injector problem or lift pump problem or.....I don't know. Where should I start????
Thanks
Jason
Thanks
Jason
My truck behaved similar... without the engine sounding like it was missing.
When I use the Smarty for pressure increase, under light throttle, my rail pressure would fluctuate like crazy. I leave the Smarty pressure on 1, and use my EZ for pressure, the irratic rail pressure ceased. I see you are running TNT-R, if you are raising your pressure with Smarty, you could try turning it back to stock pressure.
You might also be draining your rail, and it's trying to recover, causing both of your symtoms. Try a lower sw#, or less tq management.
It may be your fca, but I would try tuning before spending money on a new FCA.
I guess I should have asked, was it ok, no changes in tuning, and all of a sudden it's acting strange? If so, then I would lean more towards a mechanical snafu.(rpm related, tps?)
Administrator/Jarhead
First, I would take the truck back as stock as I could get it... (take off the smarty).
This sounds like a bad fuel flow to me... have you replaced your filter on the Fass?
Do you have an isolator on your FP gauge? That could also be a culprit for the FP, not the RP, tho.
This is a problem that seems to have started out of the blue. I've been running tnt/r for quite awhile and never noticed a problem til now.
I took the isolator out because it was giving me problems
I'll try taking the truck back to stock tomorrow also and see how she runs
Thanks Guys
Yep got her fix up! Replaced the little filter before the FASS pump and everything is back to normal. It was such an easy fix I feel stupid for even asking for help
Thanks Guys
Jason
Thanks Guys
Jason
Was it a little inline fuel strainer, like a Fleetguard FF5079?
