Any experience/info with this intake?
I've already searched, (that doesn' mean much though - I can put in the same search terms and come away empty and someone else gets hits)....so...anyone?
http://www.wilsonmanifolds.com/content/view/42/63/
No mention of price that I can find. Wonder what the cost is?
All they did was fool the dyno. It's a dumb trick. If you look at the peak, it is very close to the same. For the dyno run with the new intake on, they started the run much earlier. This is going to show increased torque and hp at a certain rpm. If they started at the exact same rpm, it would probably be 5-10 hp, not 30 hp and 79 lbs of torque. Imagine why they cut the dyno graph off after 2500. It shows almost no improvement after that.
Don't spend money with someone that is trying to trick you.
Taz
Mar 21, 2005 08:10 PM
texasaggie2005
16
Oct 25, 2004 11:24 PM
Turbo Boy
Mar 13, 2004 08:20 PM
