Amp Steps Help
Old Mar 11, 2008 | 02:53 PM
diggity dodge's Avatar
Amp Steps Help
IM TRYING TO INSTALL MY AMP STEPS EVERYTHING IS GOOD EXCEPT PASSENGER SIDE WIRING I CANT FIND THE RIGHT WIRES FOR THAT SIDE DOES ANYONE HAVE A 07 WIRING DIAGRAM OR PICS OF THIER INSTALL?
Old Mar 11, 2008 | 03:01 PM
cbrahs's Avatar
making a call to my installer now. be right back
Old Mar 11, 2008 | 03:08 PM
Foxborough's Avatar
The body builders guide has electrical schematics on it. It's kind of hard to read thru but should answer your question. Just watch out it is a big file, I just downloaded it and put it on my computer. http://www.dodge.com/bodybuilder/
Old Mar 11, 2008 | 03:24 PM
cbrahs's Avatar
at the healight switch, there re 2-3 purple/white, purple/gray, purple, and 2-3 purple/yellow wires. take a test light and find the trigger wire that lights up when you open the passenger door. should be good to go.
Old Mar 11, 2008 | 05:44 PM
Alright i will try there at the headlight switch I went to the same wire colors just down the harness by the pedals and the passenger side stays down cause its getting a ground some where its kind of weird the brake switch has the same wire colors
mjbarr99
Nov 27, 2016 02:15 PM
BlackSunShyne
31
Apr 10, 2007 08:06 PM
jtharvey
Aug 28, 2006 07:14 PM
