Aftermarket Tappet Cover & Oil Pan Removal
Old Dec 20, 2010 | 09:15 AM
EdmontonCanada's Avatar
Question Aftermarket Tappet Cover & Oil Pan Removal
I'm probably not calling it by the correct name, but is there an aftermarket tappet cover/cylinder head cover (plastic part w/oil cap)?
Also, would it be a really involved process to remove an oil pan off the engine or could one just slip it out after removing the bolts?
Old Dec 20, 2010 | 09:19 AM
soulezoo's Avatar
DTR 1st Sergeant
To the "tappet cover" yes. There are a couple of folks that do aluminum billet covers. I think Hellman's may be one, not sure.
The engine will have to be lifted some (not a whole lot) from the mounts to get the oil pan out; it won't just "slip out".
Old Dec 20, 2010 | 09:44 AM
JHardwick's Avatar
Just unhook the shocks from the axle and jack the truck up, no need the unbolt the motor.
Old Dec 20, 2010 | 09:57 AM
Any websites for the tappet cover?
Old Dec 20, 2010 | 12:51 PM
mq105's Avatar
How does that create more room between the oil pan and cross member?
Old Dec 20, 2010 | 02:35 PM
cbrahs's Avatar
it doesn't.
still have to lift the motor
Old Dec 20, 2010 | 06:37 PM
cLAYH's Avatar
Originally Posted by cbrahs
it doesn't.
My thought as well.
When I did mine I pulled the valve cover, and the rockers and injectors for the two back cylinders then lifted the motor up. This gave me adequate room to remove the oil pan while leaving the pickup on.
Redline Ram
Apr 2, 2023 07:13 AM
Reapertura
May 9, 2012 02:49 AM
freds89
Jun 17, 2009 09:46 PM
bostongsx
Sep 25, 2006 11:25 PM
blueberry
Dec 5, 2005 10:49 PM
