AFE Stage 2 ??
Old Jan 26, 2008 | 10:36 PM
bigwilly's Avatar
AFE Stage 2 ??
GUY WONDERING IF ANYONE IS USING AFE Pro Guard 7 Stage 2 Airbox ? I HAVE A 03 WITH EZD1000C OTHER THEN THAT MY TRUCK IS STOCK . CAN SOME ONE TELL ME WHAT THESE INTAKES ARE LIKE AND THE PROS & CONS ARE ? ALSO WILL THEY MAKE THE TURBO LOADER .THANKS
Old Jan 26, 2008 | 10:41 PM
Silverram03's Avatar
I really like mine and yes it will make your turbo substantially louder. But man does it sound good!
Old Jan 27, 2008 | 12:49 AM
Luvnacumns's Avatar
Yep your turbo will scream!!!
Old Jan 27, 2008 | 01:23 AM
silkywoods's Avatar
if you like loud whistling, it has your name written on it
Old Jan 27, 2008 | 01:32 AM
bigjohn04's Avatar
Like the others say you will hear the turbo. It also seems that it spools up a little faster and looks cool when you pop the hood. However if you don't want to spend that much try doing *****'s Whistler Intake.
Old Jan 27, 2008 | 06:37 AM
bigwilly's Avatar
OK THANKS GUYS But will it make any power diff with the EZD1000C ?
Old Jan 30, 2008 | 10:37 AM
canadiandiesel's Avatar
Wink
[QUOTE=bigwilly;1913055]OK THANKS GUYS But will it make any power diff with the EZD1000C ?[/QUOTE
diesel trucks are basically air and fuel, once you put more fuel in, you need more air to balance out the mixture, stock air intakes are for stock fuel settings, more fuel needs the air or you will just blow smoke like so many jokers out there. i cant remember where i found it but there is a graph that shows fuel to air cfm mixtures for optimum power. up to 500hp at the crank, replacement air filter in the stock box will do fine, over that and you need stageII stuff, intake manifolds, and so on. i need my trucks for work and keep them below 450hp, i like the big air intakes for ease of removal when cleaning and of course that sweeeeeet turbo sound.
Old Jan 30, 2008 | 11:08 AM
Hillbilly Delux's Avatar
i have the k&n, the intake tube is considerablely smaller than the turbo, so i have to crank the clamp down really tight. is the afe tube the same size as the turbo?
Old Jan 30, 2008 | 11:46 AM
bigjohn04's Avatar
The AFE is the same size on my truck.
Old Jan 30, 2008 | 02:35 PM
mxg342's Avatar
I have the stage 2 and for a while ran with the silencer ring removed. It was louder than my exhaust. Now the silencer ring is back in and the truck runs great.
Old Jan 30, 2008 | 04:44 PM
who wants to buy a K&N?not only have i bought performance parts for my truck, but it seems im buying better versions of the performance parts i already have. Its to bad you cant put a gooseneck ball in a viper......on 2nd thought that might be cheaper!
Old Jan 31, 2008 | 12:51 PM
Lionhart75's Avatar
I put the stage 2 on and have about 8k on it i had a instant mpg jump avrage of 1.5 and better low end preformance. Yes it is louder and now i can get some turbo bark if i get off it fast but that is more driving style then anything. it can be avoided. Over all it is a little expencive but worth the money. I would do it again.
Old Jan 31, 2008 | 01:13 PM
C Minus's Avatar
1.5MPG overhead jump or hand caluclated per tank to the same spot in the fill neck each time?
Old Jan 31, 2008 | 02:25 PM
JoeLee's Avatar
AFE stage II is a joke@ maybe if I could make it so the box did not surround it and rob it from its true potential, maybe a reason also is that im running a dry filter as well?
Im going to the scotty II
Old Jan 31, 2008 | 05:24 PM
Lionhart75's Avatar
Those number i got doing the numbers by hand. Now this being said I put the intake on after the edge. The combo might be the key to the mpg jump and the afe alone may not me as large.
As for the surround around the filter. Its purpose is to sheild the filter and incoming cooler air from the hot air comming through the raidator, intercooler, condencer and the engine it iself. Unfortunatly dodge didnt realy provide a clear path for airflow or means to inprove it. I have only seen two real optons to inprove on the design. One is to insall a ram hood that is functional and adapt the sheilds to the hood ductwoork or put a custome grill on the outside of the fender. The oem air path is ok but leaves alot of room for improvement. One other concern when it comes to the filter is water. a direct air path sounds great untill it rains and your engine is breathing through a wet tampon.
3500eh
Jul 29, 2008 04:53 PM
TORQUE BEAST
Jun 8, 2008 07:53 PM
goodeyesniper75
Aug 29, 2007 11:54 AM
052500#1
13
Jan 6, 2006 03:27 PM
