AD 100 vs AD 150
Old 12-25-2008, 10:23 AM
D45
D45's Avatar
AD 100 vs AD 150
I have heard that the AD100 is much more easy to install than the AD150.......yes or no?
Does the install differ, on either, since my stock LP died and was replaced with the dealer installed in-tank retro fit kit?
Old 12-25-2008, 11:44 AM
04DEEZELRAM's Avatar
Since you have the in-tank pump the install is going to be the same, you will have to run a draw straw.
Old 12-25-2008, 01:06 PM
TrkEnvy's Avatar
With the AD100 you can use the stock pickup.. With the 150 you will need a drawstraw due to the pickup being too restrictive. Some guys on here have the drawstraw 1/4 tank prob so take your bed off to install in its natural location. Also cbrahs said something about augering a hole in the canister. That is what I plan to do when I find my next truck. First mod its getting is a AD150.
Old 12-25-2008, 01:19 PM
He has an in tank pump so he is goin to need a pick-up tube
Old 12-26-2008, 05:22 PM
D45
D45's Avatar
So on either kit I will need a draw straw......it just boils down to what gph rating I want, the 100 or the 150?
Since both are the same price, I may as well get the 150.
Old 12-26-2008, 05:26 PM
Fisherguy's Avatar
... not if he removes the pump from the canister.
If you draw from the canister you need to plumb the AD return into it though or you'll have problems when you get low on fuel.
53 willys
38
11-06-2008 11:18 AM
dodgediesel
26
11-02-2008 12:20 PM
curts99
02-14-2008 12:09 AM
heavyJ
10-25-2007 09:08 AM
Ramtuff06
08-21-2007 06:21 AM
Quick Reply: AD 100 vs AD 150
