A5k vs
Old Sep 18, 2007 | 07:00 PM
rippit's Avatar
A5k vs
how much bigger is an ht3b than a A5k. that is an A5k as the bottom turbo in the ATS twins set up. how much more air will the ht3b flow as a bottom turbo in a set of twins.
Old Sep 18, 2007 | 10:01 PM
rippit's Avatar
come on I know sombody knows
Old Sep 18, 2007 | 10:05 PM
Pack Mule's Avatar
i know the exhaust housing is to small for big flow on the A5K. are you wanting to go twins or a big single?? if you're looking for twins the phat shaft twins from industrial is a very good setup. i think the ht3b is a larger charger but not by much.
Old Sep 18, 2007 | 11:43 PM
chrleb1's Avatar
The HT3b is not that efficient. They are some better ones that will flow more also. The s400 turbos are nice for the big turbo.
Old Sep 19, 2007 | 12:45 AM
WUnderwood's Avatar
if your going to run a heavily fueled truck, a Aurora 5000 is a pretty good single, I think
Old Sep 19, 2007 | 12:48 AM
jwb600's Avatar
x2 on that. mine isnt that heavy fueled and I drive it daily.
it seems to surge less than my sps 66 did on my 05.
Old Sep 19, 2007 | 01:16 AM
PourinDiesel's Avatar
HT3B is comparible in sizes all the way around...you can get the A5K/K31 with turbine housing just as big as the HT3b.
The A5K/K31 will flow more than an HT3b.......
AND the K31 will take some abuse where the HT3B would have long since grenaded....
We see 60+psi out of our A5K based K31's.
When you get the HT3B in a single form to make boost before next year give me a call...I'll buy one!!!
Old Sep 19, 2007 | 06:00 PM
rippit's Avatar
I am looking at these two turbos as bottom turbos in a set of twins. what I want to know is will the A5K in the ATS twins set, out flow a HT3b as a bottom turbo in a set of twins. I think the A5k in the twins has a bigger housing than the ones everyone uses as a single or am I way wrong here.
I still havent made up my mind of big single or twins yet.
Old Sep 19, 2007 | 06:28 PM
what I want to know is will the A5K in the ATS twins set, out flow a HT3b as a bottom turbo in a set of twins. .
Yes it most likely will but they are similar in size and characteristics however the A5K in the twin setup will spool faster and provide more efficient boost in my opinion.
The HT3B is more antiquated technology...
If you want real efficient in a primary I would suggest an S400 Borg Warner their company reps told me it will outflow their own K31's.
Old Sep 19, 2007 | 08:34 PM
cameroneod's Avatar
I've only had them in a couple days, but Im happy with my twins.
Old Sep 19, 2007 | 08:53 PM
GT42R's Avatar
What do you guys think of building a compound setup using a GT37/GT4202R. Someone told me that would not produce more than 600HP but I also heard a properly fueled setup will produce 85 percent of what the bottom turbo is rated at. The BD twins are both way smaller turbos than A GT4202 and those can flow more than 600HP.
Old Sep 19, 2007 | 10:30 PM
morkable's Avatar
what are the big differences between the a5k and a silverbullet?
Kevin
Old Sep 19, 2007 | 10:48 PM
OutOfSight's Avatar
It may be easier to find specs for a K31(A5K)...might be my new small charger in my twin setup :-)
Old Sep 19, 2007 | 11:01 PM
SMOKIN-U's Avatar
if a guy were to run a big single what would you guys suggest a a5k or like a upper 70's mm s400 or could you even spool one that big
Old Sep 19, 2007 | 11:17 PM
morkable's Avatar
As for a single I am very happy with my silverbullet, I am only now finding that a little more air would be good. And I am putting out some pretty good power. And I ran this turbo before I had much in the way of power adders, so I am pretty much sold on it
Kevin
