A5000 verses SilverBullet
Old May 26, 2008 | 05:37 PM
Speed Shift's Avatar
I am looking at running a large single turbo, and I am down to either an A5000 or SB. I know the SB lights really well for what it is, but how does it compare to the A5?
I will start running it with a modded CP3 and 90hp injectors, then hope to go to twin cp3s and really large sticks. Also maybe one day throw a S4T underneath, I hear the SB/S4T is an AWSOME setup.
Thanks fellas!
Bodie
Old May 26, 2008 | 05:48 PM
White97GTVert's Avatar
I don't know about a 66 Silverbullet in a twins setup... Maybe the Silver 62 but man that's alot of air with a 66. I think it would be laggy. I'm sure its an awesome setup once you get it spooled though!
As far as comparing either, I've had neither, so can't comment as to personal experience.
One thing to note though is that the A5K is not wastegated, so if your gonna throw big fuel at it that may become a problem.
Old May 26, 2008 | 05:52 PM
A SB/S4T are the same turbos in the II race twins. I would run an ext WG with the A5 fo sho.
Old May 26, 2008 | 05:53 PM
What are your plans for the truck? Sledpullin? Draggin? Dyno crusher?
Old May 26, 2008 | 06:04 PM
A little of everything. It will also be a daily driver.... untill the S4T goes on that is.
Old May 26, 2008 | 06:40 PM
Bswope's Avatar
The A5K is a bigger charger then the SB and is gonna move more air.
Old May 26, 2008 | 07:02 PM
king d's Avatar
sb is a better all around turbo for towing and driving.the 5000 has the edge in all out performance...
53 willys's Avatar
I think a SB would be cool....then you could do twins and put the SB on top....just like II race twins...altho doesn't the II race twins have a modded SB????
Old May 26, 2008 | 07:06 PM
Bswope's Avatar
Of course u could run the A5K over a Phat Edit in a twin setup like the PDI truck!!!!!!!!!!
Old May 26, 2008 | 07:20 PM
durasnack's Avatar
I vote SilverBullet Mr.Armstrong....i might know about them i had mine to 70psi before i blew the heater core on a dyno in houston
Old May 26, 2008 | 07:31 PM
99globalwarmer's Avatar
get a custom charger if your gonna spend the money and ya you could throw a smaller primary under whatever on top and daily drive.
Old May 26, 2008 | 07:45 PM
Thats what Im talkin about!
Old May 26, 2008 | 07:54 PM
Like durasnack knows, I am a different person, and I like to have something not many others have. I really like the SB and was content untill I saw the SB and A5 are about the same price.
As I sat at my comp I gave it the old "huummmmmmmmmmmmm"
You guys know what im talkin about!
Old May 26, 2008 | 09:44 PM
durasnack's Avatar
Different is an under-statement, but in a positive way. Your (my old) FASS pump in your bed is a prime example. You are an innovator, never following the lead....well, except on your SouthBend and Smarty decisions jk Bodie
Old May 27, 2008 | 06:26 AM
PourinDiesel's Avatar
Been running an A5k for 2 years now and its still going strong. If I had it to do all over again I would buy the Aurora 5000 again in a heart beat.
