6-speed up grades and ppe tuner
i got an 05 crew cab long bed dully 6-speed and want to know what should i up grade on my trans.. its only got 35,000 on it.. also what do u guys think of the PPE tuner vs the SMARTY tuner...and is the TST box a chip like ajustable on the fly, or is it a tunner.and are they any good.. and i read something about draining the (fuel rails) with the tunners/chips.. not sure what that is, i guessing the motor is sucking more fuel than the fuel pump can keep up with..??? thanks guys..
tst is adjustable on the fly. works pretty much like the edge juice just alot more aggresive. when a box drains the rail it is using up pretty much all the fuel that is in the rail available. thats why alot of guys are running the dual cp3 pumps to support their big injectors, boxes etc. im sure someone will correct me and give you the full long explanation but hope it helps you
well alot of guys dont. from what I see on my truck I want them. I dont run a standard program in the tst its the twin turbo program so it takes alot of fuel to run it on high levels. you can stack stuff and be fine just depends on what settings you run the stuff on.
studio5o
18
Jul 3, 2015 12:19 AM
jivemother
Jul 17, 2008 09:11 PM
Turbo Deeezle
16
Oct 7, 2004 10:38 AM
