50hp or 90hp injector for HP goal?
Looking for a little input. My HP goal is to be streetable around 650hp on fuel.
I'll be doing twins with the stock over ???, studs, Arisin III pump mod, smarty stacked with Quad Std pressure, and built trans.
Do you think that this can be accomplished with 50hp or 90hp injectors? Is there a difference in fuel mileage better the two? how close to that goal can I get with 50hp sticks?
Also am I missing anything or need to change my mods to get there?
Thanks a bunch to the brain trust at DTR!
if your going with the pump mod go with the 90. I would stay away from any more pressure adding than the smarty. It could be done with the 50 but will require a little higher setting on the smarty. You will likely make over 650 for show but get a reliable 600 with your plans.
vj_M
Feb 11, 2008 10:18 AM
SlowSixSpeed
Nov 22, 2007 04:15 PM
frostytj
Apr 20, 2007 11:32 AM
ramtd02
Apr 19, 2007 06:16 PM
PourinDiesel
Apr 2, 2006 09:38 PM
