500hp and 1000ft/lbs
Old May 20, 2008 | 10:14 AM
Jason_K's Avatar
With the mods in my sig, am i there yet? If not what do i need first.
Old May 20, 2008 | 10:35 AM
dzlfarmboy's Avatar
Should be in the high 400's, close might just need a tad bit more fuel. you have the air.
Brett
Old May 20, 2008 | 10:36 AM
soulezoo's Avatar
DTR 1st Sergeant
With the turbo and TNT you're there... as long as your fuel supply is good which it should be at that level; might want to consider lift pump upgrade.
Old May 20, 2008 | 10:46 AM
matego's Avatar
madhat's monkey boy...
Yeah, I would say you are there also. What kind of fuel pressure do you have with the stock lift pump at WOT? Like Soulezoo said, I would consider a good lift pump and definetly a 2 mic. filter to keep your injectors happy.
Old May 20, 2008 | 10:52 AM
Bswope's Avatar
Ur there now, i did 488/966 on the stocker, did 476 with just the TNT on SW#7 and then the TST on 2/0 it did 488/966! Hepled another fella with a truck just like mine but he had a Silver Bullet 62, stock everything else even fuel system and with an Edge A2 he did 524/1091, then we loaded my Smarty TNT up on Sw#9 TM4, Timing2, RP3 and wastegate off it did 551/1126, then we tried SW#8 TM4, Timing1(stock) RP0, and wastegate off and Edge on 5 and it did 572/1088.
Old May 20, 2008 | 10:56 AM
Jason_K's Avatar
i actually have a FASS 95 sitting at the house but my fuel pressure pretty much maintains 5psi so i wasn't sure how much the FASS would actually help at this point.
Old May 20, 2008 | 10:58 AM
Bswope's Avatar
Where u at in PA?
Old May 20, 2008 | 11:01 AM
Jason_K's Avatar
bswope, those are some real nice numbers with that stock turbo. I'm from hastings, about 20miles from altoona.
Old May 20, 2008 | 11:47 AM
Jason_K's Avatar
thanks for the reply guys. i was curious because last month i dynoed on a Superflow with Smarty 4.11 on SW9 w/wild TM. I had the stock turbo then and put down 433hp and 843ft/lbs.
Old May 20, 2008 | 12:00 PM
Bswope's Avatar
Im about 30mins south of Altoona, 10 mins from Breezwood, some buddies and i used to go to a bar up that way called Classics chasin skirts!
Old May 20, 2008 | 12:09 PM
Jason_K's Avatar
hahaha, yeah i know were that's at! I go past there just about everytime i go to altoona, which is pretty much every week.
Old May 20, 2008 | 12:20 PM
hoot's Avatar
I just dynoed 541/1039 see sig
Old May 20, 2008 | 12:41 PM
Jason_K's Avatar
A couple questions. Do you still have a stock cp3? and do you know what type of dyno you were on?
Old May 20, 2008 | 01:19 PM
hoot's Avatar
Stock cp3, Dynojet
Old May 20, 2008 | 01:55 PM
Jason_K's Avatar
very impressive
