is 50% on mp-8 safe?
Old Dec 29, 2006 | 08:17 PM
omaharam's Avatar
Ok so I might be trying an mp-8 to see how it compares to my xzt for adding pressure. I know that the mp-8 can add more pressure and thus more power, but I also know it's not safe to turn to 100%. I just ordered a GDP lift pump system and am doing a cp-3 in two weeks (and dynoing at the same time - finally) and so I can't really afford $300 for a rail pressure gauge. I would still like to test the mp-8 against the xzt on the dyno, but not sure how high I can turn it up safely. After searching posts, it APPEARS that up to 50% is safe.
Any input?
Old Dec 29, 2006 | 08:29 PM
MikeyB's Avatar
In CP3 do you mean a aftermarket CP3?
If so you shouldn't need a pressure box with a modified CP3. Running both together will damage the injectors.
MikeyB
Old Dec 29, 2006 | 08:52 PM
omaharam's Avatar
MikeyB
Haven't heard that. When I talked to John at Floor-it, I told him exactly what I had for mods and he didn't say anything about using a modded cp-3 and pressure box together being a problem. Doesn't the modded cp-3 simply allow you to hold a certain pressure instead of it dropping off like the stock cp-3 would? I hadn't read that a modded cp-3 alone raised rail pressure all on its own.
Old Dec 29, 2006 | 09:16 PM
masonic-dodge's Avatar
That is true, Pressure box + modded CP3 = breaking the inturnals in the injectors. If you are going to get a modded CP3 don't use a pressure box.
CRIS
Old Dec 29, 2006 | 09:30 PM
omaharam's Avatar
CRIS
So the flux2s can handle it, cuz you have a cp-3 and mp-8 listed in your sig.
Old Dec 29, 2006 | 09:49 PM
The tips can handle it, but the inside parts can't I broke 2 of them!!! I don't run the MP8 anymore.
I'm going to put the MP8 back on when I take my II stage 2 CP3 off and sell it. I'm going to build another truck and detune my 05 so the pump and Flux2s are coming off and being sold.
CRIS
Diesel Dave
Jul 9, 2003 06:54 AM
popeye
Jun 24, 2003 11:11 AM
BEHRMAN
Apr 3, 2003 05:02 PM
AKDSLDOG
Mar 14, 2003 10:17 PM
AlpineRAM
Dec 22, 2002 09:04 AM
