42psi Boost
Old Jan 4, 2007 | 09:32 AM
vj_M's Avatar
42psi Boost
I have an edge ez in my 04 3500 and the boost gauge was always showing 42psi maxed ouT! I took it out the other day and put it back in now all its showing is 32psi...
Was this posible or was something just messed up..?
and if so.... what happened.?
VJ
Old Jan 4, 2007 | 09:55 AM
dodgezilla04's Avatar
has the fuel filter been on there a long time? low fuel flow will cause low boost since boost is dependent on exhaust gasses
i assume you have mechanical guages? if it is a digital meter, like an outlook or quad commander, make sure the connections are good. then start checking the intercooler piping and clamps for leaks. after that, pull of the aircleaner boot at the compressor inlet and check the condition of the impeller, shaft play, oil in the compressor housing, etc.
Old Jan 4, 2007 | 11:06 AM
Dodgezilla's Avatar
I think 32 sounds more normal if yours is a 305/555 engine.
Old Jan 4, 2007 | 12:53 PM
goodeyesniper75's Avatar
yea 32 is normal for our trucks
Old Jan 4, 2007 | 01:11 PM
but he had previously run 42#'s. why the change fellas?
Old Jan 4, 2007 | 01:18 PM
Dodgezilla's Avatar
The question is why or how did he get 42psi out of his stock turbo with just an EZ box on it?
Old Jan 4, 2007 | 01:20 PM
wonder if the gauge was faulty to begin with?
Old Jan 4, 2007 | 01:47 PM
vj_M's Avatar
good bunch of answers..! But at high speeds the turbo use to wind like really loud now its not so bad... but it said 42 and i Have the 325 engine it says on the block but its an early 04 march i think..
and i never changed nothing as far as fuel filters go. maybe a glich in the chip its self.?
Old Jan 4, 2007 | 02:06 PM
never changed the filter?!?!?!?!?
gotta do that one often. about every 10k miles. change your fuel filter and see what happens. takes about 5 minutes, 10 if you get a bucket and rags to clean up with.
Old Jan 4, 2007 | 03:44 PM
ZacHolley's Avatar
how many miles have you put on it without changing the fuel filter??? i think i'd be spendin 20 dollars for one with a quickness
Old Jan 4, 2007 | 03:57 PM
973604x4's Avatar
the EZ is supposed to do boost fooling...on pre 600 trucks it has an adjustable boost elbow that does boost fooling. Its supposed to boost fool on 04.5+ but it didn't seem to do much for me when I had one with a stock turbo.
Old Jan 4, 2007 | 04:23 PM
MrSlug's Avatar
I put the same question to Edge. I have a Juice/Att combo and I see boost pressure of 41-42 if I get on it hard. Basically the reply I got was stating the boost readings are high do to the fact I am at Sea Level. He told me since I was at sea level I could actually move my defuel point for boost up to 39 without difficulty. Hummm.
Old Jan 4, 2007 | 04:59 PM
Dodgezilla's Avatar
42psi is normal on an 04.5 thru 07 325hp engine with some sort of programmer. So I would now conclude that something got out of whack when you pulled the guage off...
Old Jan 4, 2007 | 10:14 PM
973604x4's Avatar
Not true.
Programmers don't do boost fooling. all you get out of Bullydog is 32psi...same with Smarty...same with any programmer.
MODULES boost fool!
Old Jan 4, 2007 | 11:01 PM
Originally Posted by 973604x4
Not true.
MODULES boost fool!
not so anymore my friend, the latest and greatest downloads for smarty provide boost fooling for aftermarket turbos. take a gander at madselectronics.com
