4.5" Tuff Country Lift Kit Installed!
Old Jul 25, 2005 | 04:26 PM
Jmac's Avatar
Thought you guys might take a look and let me know how it looks. Pics in my gallery.
I have a bit of a wobble at 60mph and up. I wonder if I drove too long without getting an alignment and messed up the tires???
thanks for any input.
Jamie
Old Jul 26, 2005 | 12:26 AM
rjordan's Avatar
ill bet that your wobble is your carrier bearing on too steep of an angle. i know on mine i had to drop the carrier bearing about 1 to 1.5 inches to make it more of a straight line from the t-case to the rear end. youll have to build your own brackets, but it aint hard, ive used 2" square tubing on one truck, and a few pieces of 1/4 inch steel strap before. but i know i had a vibe from about 60 on up too till i did that, then there was no vibes at all clear to 110 mph
Old Jul 26, 2005 | 01:14 AM
CrashCade's Avatar
That is 4.5 on a 4x4? Ouch... What did that lift cost you?
Old Jul 26, 2005 | 08:35 PM
Jmac's Avatar
Got it from a member on this site. Got it for 450 and trade for my Bilstien shocks.
Carrier baring is droped about 1 1/4". The shake is coming from the front end. I think it's the tires. I think they wore incorrectly, once I lifted it I had to drive it for a day at work. I'm going to try and rotate them tomorrow.
jamie
Old Jul 27, 2005 | 09:02 AM
bchesley's Avatar
The alignment must be right. These trucks are finicky when it comes to getting this right. Do you know what the alignment was set at? Caster degrees? Toe-in?
Brad
Old Jul 27, 2005 | 06:00 PM
Jmac's Avatar
No. But I had the dealership I do business with align it and I have confidence in them. Could it be the stearing stabilizer? Could it be that I used a tapered 3" rear block and the angles are off on the rear drive shafts? I did drop the carrier baring down about 1 1/4", which took away the shudder at stop to 12mph.
any help would be great.
thanks Jamie
Old Jul 28, 2005 | 11:31 PM
Jmac's Avatar
Called tuff country and they told me it's the 3" tapered block. We took the 3" block out and reinstalled the 2" block and presto, wobble 90% gone. It has a lot to do with the pinion angle of the rear axle and the differential. The angle has to nearly be perfect.
Still need to shim down the carrier baring a little, will do that tomorrow.
Jamie
lvmknsmoke..
Mar 25, 2009 05:57 AM
2-Stroke
16
Nov 30, 2006 12:50 PM
Jmac
May 16, 2005 10:10 PM
kry226
Jan 29, 2004 07:09 PM
