3rd Gear launch 60' times ?
The only way your going to get deacent 60ft in a NV5600 is doing a boosted 3rd gear launch. Simply reving it up and dumping it at 3psi isnt going to work.
You need to get a line lock and a DD clutch.
Slip your new DD at the line to build boost 10-20psi and then you will turn some good 60ft.
Your stock clutch isnt going to hold the new power from a turbo and improved electronics.
What are you thinking????? Your talking about adding nitrous to a pretty much stock truck so you can shave 2/3 of a second off your ET
Get some supporting mods that will make your truck live a much longer happier life because your going down a road thats going to hurt your truck.
Spend your $$$ wisely
Most of the information I have compiled from this site and others have shown there is not a "huge" improvement over a 3rd gear launch compared to what I am running. Most are getting 1.75-1.85 tops. I have a lot of wheel spin at the line and I am going to get some traction compound and soak some into the rubber.The EGT's are well within limits at the end of a quarter mile but I have just tapped the exhaust manifold to check drive pressure. The NOS would be used to light the turbo at the line and if during testing I find the drive pressures get too high I will put a pressure switch in to kick it out at 20-25 psi. If I thought a bigger turbo would make a difference, I would be on the phone to HTT tomorrow. I have a pyro before and after the turbo because I cant figure out why everyone is having high egt's with stock turbos. Remember, I might be pushing 475hp on a great day to the back tires and I have been running pretty respectable times. The clutch is the strongest single disc I could find. I have a fine collection of Con FE's, Sintered Iron, Kevlar discs in the basement. I have driven trucks with double disc clutches and it makes a huge difference on shifting, although I have not tried a Haisley strip clutch yet. I was mostly looking for hard facts here but most serious drag racers here run autos. I am not sure what supporting mods you are in reference to. My rail pressure stays 22-24k, CP3 fed 28psi, open exhaust , bigger CAC etc. But hey, everyone has a opinion
Your truck is fine if you keep it for intended pourpose but if still feel the need for more speed then there's going to be alot more on your plate.
I'm talking and this threads should be titled 3rd gear BOOSTED launch times.
Boosted launches is how autos have advantage.
Have you even been in a 500hp CTD doing a 4x4 20psi boosted launch????
Well it is like being on a launch pad....
Simply dumping the clutch in 3rd gear is like an auto not doing a boosted launch, and they dont do that.
What you need is a simple $80 line lock from Summit Racing and a DD thats rated for it.
Lock your tires with the lock and then rev the engine and slowly let the clutch out until it starts slipping and building boost until 20psi or so and the release all the brakes and hold on because you just turned a 1.8 60ft.
This is key if you really want to drag race your manual.....
As you are now learning autos rule at the drags and ther wifes can still drive them around town which is kinds hard if you have a 3850 DD.
After reading this thread, I had to try the 3rd gear launch. Did it last night in 3rd, 4x4. Dont know how much boost I built but I used the 3 foot method. It did not bog the engine down or spin any tires. It did feel like it would have been a little quicker on a timed run.
[QUOTE=SlowSixSpeed;1715389]
QUOTE]
That was the whole purpose of this thread. 1.8's are usualy what double disc clutches are turning. I am now 1/10 of a sec. off of that. I will give 1/10 for the faster shifting clutch. If you put race tires in the equation it is a different story. Anyway it is pointless to stay here and argue about what it could or might do. As soon as we get a decent cold snap here, I will know what it will do.
QUOTE]
I guess if the 3rd gear launch doesnt shine in the 60' is it more noticible in the 330'? I guess what I am really getting at is the single I have holds a 2nd gear 5psi dump at 2500 really well. My goal is to crack into the 13.2-13.3 range and I think I can do it with some spray and a top end program. I am starting the 2k will be better spent on a new turbo instead of a double disc. My egt's are good, but I know the small exhaust size is killing my top end.
Take a look at this time slip and see what you guys think. Would you improve on the top and try and gain the time from 1/8 to 1/4 or try and get a better launch? This slip is pretty much in the middle of what I run.
Im not 100% positive but picking up 1/10th in the 60ft can result in cutting 3/10 in the 1/4.
That 1.8 was just a guess and im betting you could be even quicker.
Heck I was cutting 1.9's on my stock + EZ on my 02HO
I like the clutch alot. Im not running crazy power, but ive yet to slip it. It also shifts as fast as I can slam the shifter around. I have the 6 button street drag.
A $80 line lock will also help out alot. If your track is like mine I still roll a little once im staged and both of my feet are too busy with the clutch and throttle.
Ive red lighted a few time because of the roll.
13ALPHA
17
Apr 28, 2008 08:44 PM
pwrtripls1
Mar 3, 2008 09:59 AM
