35's on dually, how much wheel spacing?
Old Aug 14, 2007 | 11:01 PM
Highmark's Avatar
Just wondering if anyone new how much wheel spacers was needed to fit 35x12.50 on my dually. I have a 5 inch lift. I know this has been asked before, but I have forgotten how much to put on the inner and in between the duals. Any answers that would be great.
Old Aug 14, 2007 | 11:10 PM
BlueDually's Avatar
2" between the duals is all thats needed, at arrowcraft.com
Old Aug 14, 2007 | 11:13 PM
Highmark's Avatar
thanks, I heard that some guys put wheel spacing on the inside becasue when you put weight in the box and hit a bump, the leaf spring/shock or something along those lines will slice and pop the tire, inless that is just a rare occasion.
Old Aug 15, 2007 | 04:24 AM
Topper's Avatar
Highmark,
I was told that a 1/2" spacer was needed to keep from rubbing on the inside of the tire. I am going to be putting a set of 35X12.50 on next week and plan on adding a 1/2" spacer first.
Good luck,
Topper
Old Aug 15, 2007 | 06:46 AM
wap's Avatar
wap
I think the need for an inside spacer depends on what tires you run. I have had no problems with mine and I dont see 315s hittin either. But if your tires run a little wide or have a super aggressive sidewall you may need an inside spacer.
Old Aug 15, 2007 | 07:00 AM
goodeyesniper75's Avatar
i was only using about 1/2" and i went to 1 1/2" because when i was towing a heavy load i wanted to be sure they didnt rub. there 35x12.5x17's
Old Aug 15, 2007 | 08:59 AM
Highmark's Avatar
Thanks everybody, I might do a liitle bit of spacing on the inside becasue I haul a gooseneck sometimes. So maybe just a 1/2" on the inside or something should work to be on the safe side, if anybody has any pictures of 35's on a dually, that would be awsome. Thanks again.
Old Aug 15, 2007 | 05:20 PM
Speed Shift's Avatar
These are just wimpy 285s but I have 1/2" spacers on the inside dual, and a 1-1/2" in between....
Several buddies are running 35x12.50's with no problem though
Old Aug 15, 2007 | 05:34 PM
BlueDually's Avatar
Ive got 9000 lbs on my back axle everyday (sometimes up to 11 000), and have not any problems with 295 toyos rubbing the leaf pack, or each other, with just the 2" arrowcraft steel spacer between the duals.
Old Aug 15, 2007 | 06:57 PM
Highmark's Avatar
Thanks for the picture, judging by everything I should be fine to run
2" spacing in between the duals and not have any problems. Thanks again.
Old Aug 16, 2007 | 06:06 PM
06dodgedrw's Avatar
how strong are the spacers? i tow around 15000-17000 every week to me they dont sound strong enough to hold that kind of weight and i have been known to put my truck over its gvwr in the bed will they hold up to that abuse?
Derek Timm
Dec 18, 2007 09:36 PM
Dwitt0187
15
Dec 17, 2007 08:09 AM
600 Megawatts
Oct 24, 2006 03:49 PM
harry j holcomb
Jul 8, 2005 03:45 PM
Mike S
Nov 30, 2004 09:02 PM
