325/65/18???Same As 315/70/17???
Old Dec 17, 2005 | 05:35 PM
ocsurf16's Avatar
I belive that they are the same tires but im not sure. Plus All H1 Rims will fit 8 lug dodges. Im getting an 04 on Monday im looking to get H1 wheels and tires. Locally this guy has 18inch rims with 325/65/18 tires...are they the same as stock wheel size that will fit on Dodges? With 2inch spacer
Old Dec 17, 2005 | 07:14 PM
merrillr4's Avatar
Hey there,
The overall diameters are very close. 34.36 for the 315's and 34.63 for the 325's. Your overall difference is about .27 of a inch. Hope that helps a little!!
Rob
Old Dec 17, 2005 | 07:34 PM
djbikeman's Avatar
For future reference
You may or may not know this, but I thought I would put it out there:
325/65R18
325 = tread width in mm
65 = sidewall height as a percentage of tread width
18 rim size (obviously)
to figure out tire height in inches:
(tread width) / 25.4 x (% sidewall height) x 2 + rim size
Hope that helps for future reference
Old Dec 17, 2005 | 08:11 PM
oestreich84's Avatar
You also have to remember that h1 wheels are 16.5". Also make sure that they are an older set of wheels because the newer model h1's have an automatic tire inflation system built into the wheel. They are a real pita to change tires on. Most shops wont even put tires on those wheels. Just a heads up
Old Dec 18, 2005 | 02:18 PM
4x4not's Avatar
If the tires he is looking at are 325/65R18s then they sure aren't on stock H1 wheels
Old Dec 18, 2005 | 02:52 PM
marc03's Avatar
close 315 vs 325
height 34.4 vs 34.7
wider 12.1 vs 13
Dirk5.9
Jan 12, 2011 02:45 PM
J Lent
60
Nov 3, 2009 09:14 PM
Death Dealer
Dec 11, 2008 10:40 AM
ocsurf16
Sep 16, 2006 09:23 PM
rjordan
Sep 27, 2004 09:25 AM
