325 60 18/33 13.50 18 Tires.....What do you run?
Old Mar 22, 2007 | 11:17 AM
PourinDiesel's Avatar
Anyone here run 18" wheels and tires?
Any all terrains for 18's out there?
Pictures?
Old Mar 22, 2007 | 11:57 AM
J Double's Avatar
Mickey Thompson Baja ATZ's 325/60/18
[IMG][/IMG]
Old Mar 22, 2007 | 12:04 PM
J,
Do you have any closeups of the tire tread? I am trying to get an idea of how aggressive it is. Right now my problem is I opened my mouth and ended up selling my tires and rims and have to find a good 18" tire I can spin off the line.
BTW...the ATZ's look awesome!
Old Mar 22, 2007 | 12:18 PM
yfz431's Avatar
Check out the Goodyear Wrangler Silent Armors. I have them in 325/60R/18's.
Much more aggressive than the stockers, quiet, ride nice and smooth, and are load range E. A bit pricey though @ $280 a tire. Good luck.
Old Mar 22, 2007 | 01:23 PM
cquestad's Avatar
I would look at the XTA from Procomp in the 325/60 or 325/65/18 sizes. I bet it is exactly the pulling tire you are looking for!
Check my reader pics for the 37/13.5 version...but tread is the same.
Old Mar 22, 2007 | 05:31 PM
J Double's Avatar
I don't have any closeups handy with me but you can see a blowup of the ATZ 's on the Mickey Thompson website.
Old Mar 22, 2007 | 06:16 PM
wap's Avatar
wap
One thing to think about on the Procomp XTAs is that they are directional.
I dont know if it matters to your or not, but a friend of mine bought a set without thoroughly researching them and he was not happy that he bought a directional set of tires.
Old Mar 22, 2007 | 06:22 PM
blcoonrod's Avatar
Not all terrian but I sure like my MTZ's
Old Mar 22, 2007 | 06:57 PM
SmokinDodge12V's Avatar
Justin, 325s wont fit under a stock truck and would be very hard to get going off the line in a high gear.
Old Mar 22, 2007 | 07:18 PM
whitetrash66's Avatar
i run revtek spacers and i can fit 325/50r20 (33x13.5R20) claws with basically no rubbing. And they are on 20x10 wheels with 4.5" backspacing. If you level the truck, you'll be fine
Old Mar 22, 2007 | 07:26 PM
35" 05''s Avatar
[IMG][/IMG]
i have been tryin to find u! can u tell us ur whole set up wheel width leveling kit, rubbin. i love wide tires. i want 12-13.50's with 12 wide rims. please help me too. not to steal the thread
Old Mar 22, 2007 | 07:30 PM
Yes leveling the front would help but he uses his truck to pull sleds and raising the front is the wrong direction.
Old Mar 22, 2007 | 07:37 PM
Pooter's Avatar
325(70/17s) fit under my truck at stock height just fine...
Rubbed a tad at full lock, but only the upper control arms, and it wasnt bad
Old Mar 22, 2007 | 08:15 PM
J Double's Avatar
The wheels are only 9" wide. I'm not sure what the offset is right off hand but they're real close to the MotoMetal 951's and stick out 2mm less.
You will need a leveling kit to prevent rubbing. The springs fixed the rubbing until I put the flares on. After I put the flares on I had some light rubbing at full lock so I had to trim a little bit off the inside corner.
