230hp power pup?????
I was on the bullydog website and i found a page that said that the cummins downloader had a 230hp setting. I called bullydog and they said that it should be available at the end of the month. The also said that we would be able to download the new program right from our home computer into the pup that you allready have. Thats a pretty good deal if you ask me. Has any one else heard about this????
http://www.bullydog.com/products/tec.../power_pup.pdf
with your stock tranny laying somewhere between the rear axle and the motor on the ground steamin like its ready to burst into flames........... sounds nice if ya got the funds to put in a tranny behind all that powah.
Is the 230 at the flywheel, or where does that number come from. The extreme setting of 130 is at the rear wheels correct. I hope it still works with the outlook monitor. How do yall think that the 6spd will like it.
Bradleysram,who were you talking to at bully dog I have a early pup and it has that flat spot between 1500-2000 rpm when I spoke to Justin at bully dog he said to send it back for the flash. If bully dog has upped this unit to 230 hp maybe I won't change over to the TST ,just do the AtS converter and valvebody to get the power to the ground stock converter sucks
