22x10 -25et offset/4.5" backspacing w/ 37x13.5x22 tires
hey guys
got the carli starter system with the control arms.
think this wheel and tire setup will fit without rubbing?
any info would be great.
thanks
thanks
I'm gonna say yes but maybe no. 4.5" backspacing will push the wheel/tire out almost 1" from stock and rubbing on the control arms won't be an issue. Stock backspacing is 6-6.25", I forget exactly. The offset doesn't really make that much of a difference as it's measured in millimeters. 13mm is about 1/2" so 25mm is about 1" and being a negative offset, the mounting surface is inside the center line of the wheel. The biggest concern is backspacing though.
However, Carli's starter system is only a 3" leveling kit so there may be some rubbing on the fenders with the 37" tires. To give you some perspective, here's a Carli leveling kit with 35" tires on 18x9 wheels with 5.75" backspacing. No rubbing on control arms or fenders. If you'd like, I could take a rough measurement from the center of the hub to see if a 37" tire might clear the fenders.
I'm running the Carli 2.5 kit w/22x9 35x12.50-22's.. It doesn't rub but if i had 37's oh it would.. I run the bushwacker flares and every once in awhile if i hit a but and turn it will touch the flare.. Now if the flare wasn't there it would be ok..
Redneck-Express
May 1, 2009 12:45 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
walnutfarmer
Dec 10, 2006 10:35 PM
